When I plug in the amp cable the receive goes away. unplug cable it comes back . any help??
John n0snx
John n0snx Member
edited October 2019 in FLEX-6000 Signature Series
Flex 6300 using 1.3.8 When I plug in the amp cable the receive goes away. unplug cable it comes back...It just started doing this... no problems before using the Alpha amp... Hooked amp to different radio and it works fine... I think maybe the relay switching in the Flex has gone haywire  .I have cold booted the radio and still have the issue.. any help??  I am aware of the issue when first starting the Flex but this is different as it doesn't go back to receive after startup.
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    Is it the same PTT cable? The reason I ask is that to make sure the PTT cable you has isn't shorted.
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    It does sound like you plugged it into the wrong jack...
  • James Kirk
    James Kirk Member
    edited July 2018
    The relay switching for an external amp is somewhat bonkers. It sometimes will key the amp when powered off and will then be normal when powered on. I believe Flex is aware of the problem. Not good in my opinion.
  • John n0snx
    John n0snx Member
    edited April 2015
    Same cable on both radios
  • John n0snx
    John n0snx Member
    edited April 2015
    it has been plugged into the same jack as it has always been and worked fine...
  • John n0snx
    John n0snx Member
    edited April 2015
    I am aware of the intermittent issue... but this is constant...
  • James Kirk
    James Kirk Member
    edited December 2014
    When it happens it is not intermittent in my case. It ceases when the radio turns on and occurs when the radio is off.
  • Steve N4LQ
    Waitaminit....It occurs when the radio is off?
  • John n0snx
    John n0snx Member
    edited April 2015
    guess I will just keep using my foot switch to key my amp like the OLD days
  • Ken W9IE
    Ken W9IE Member ✭✭
    edited December 2016
    I had the "No Receive" Problem with my 6500 and called Alpha.
    I thought it was a bad Vac Relay in the Amp..
    They told me it was the cable and Sure Enough That was the problem.
    Ken  W9IE
  • James Kirk
    James Kirk Member
    I should say the radio is on but SmartSDR is not running. The output of the control line is low keying the amp until the software is started then operation is normal.
  • Burch - K4QXX
    Burch - K4QXX Member ✭✭
    edited May 2016
    I have this same issue with my 6300.  Turn on the radio and it keys amp until Smart SDR is running.  Then works as it should.
  • Steve N4LQ
    Interesting...My amp is an Elecraft KPA-500. I can't tell if it's being keyed or not since there's no relay in it and nothing to indicate it's being keyed. I would have to use a vom to measure the resistance at the end of the amp key cable.
    This could explain why some report the issue and some don't.
    At this point I don't see how it could be a software problem because it happens before software is loaded. It reminds me of how rigs get keyed by serial ports as the pc boots up.
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited December 2017
    The amp keying before SSDR loads is a known issue with the 6300 only and was entered into the bug tracker several months ago
  • Steve N4LQ
    edited January 2017
    Too bad we can't have access to the schematic.
  • Nigel
    Nigel Member ✭✭
    edited October 2019
    Good comment Steve, is there a reason for no schematic?  May be the PTT line is floating a little and needs to be tied to "high" with a 10K resistor?
    Also is the station earth real good?
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    thanks Howard..  that explains why the preamp on the Pixel antenna kept being keyed off each time I tried to hook up the keying relay on the 6300 remotely before I went to the shack and started SSDR.
  • KY6LA_Howard
  • KY6LA_Howard
  • Ernest - W4EG
    Ernest - W4EG Member ✭✭
    edited January 2015
    You must be banging your head against a wall Dr. Howard.
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    John,
    Make sure that you are connecting your Keying input of your amp to the "TX"  jack on the rear of the radio and not the "PTT"  connection .   The Keying and ALC connections are not next to each other.
    Dudley
