CPU utilization with SSDR 1.3.8
I am very interested in your results; however, it is not possible to read the information from the screen shots. Please post your findings in your text rather than relying on it being possible to read them from the screen shots. Thanks.0
Hi Jim,
FWIW, when I click on the image in the community it opens up to full size and can be read more easily.
I can see that the CPU utilization for SSDR goes from 7.2% with 1 panadapter to 82.4% when 8 panadapters are open. And the CPU shows 100% total utilization with all 8 open.
I suspect the high utilization is what Sergey is trying to show. (my 6700 is being PENed currently so I can't provide any feedback currently)
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Hello Sergey,
Here is a screen capture in a Powerpoint slide (only way I know how to attach right now) of my 6700 running with 8 slices, DXLab Suite (all modules), SDRBridge, 4 instances of CW Skimmer, FLdigi and finally iPad running K6TU Control. My computer running Intel i7 hexa core Processor, 12 hyperthreads, overclocked at 4.6 GHz, 32 Gb of 2100 MHz DDR3 RAM, AMD R9 390 graphics card with 3 Gb of video RAM. All 12 hyperthreads and 6 physical cores show evenly loaded at about 55%. However, the sound of the audio is raspy, probably due to too much multitasking of sound card output. Hope this helps:
Al, Thank you so much. I was looking at the image in the email I received rather than here on the Flex Community site. What was I thinking? Sergey, thanks for bringing this up, and I apologize for not checking the Community site first. I've been experimenting with this load issue also. Have you tried adjusting the priority for Smart SDR; I've even tried going to "real time" just to see the effects. Of course that will affect whatever else is running on yu computer. One of the many great things about this Flex hardware and software is the opportunity to try such options and see just how far supporting computers may be pushed. -- Jim, W5HFS1
Sorry, DDUtil is also running. Only software not running is WSJT-X.0
Oops, one final correction of typo. Graphics card is R9 290.0
I am a simple man and can only keep up with one slice at a time, perhaps two on a good day.0
Hi Jim,
I normally don't run more than 3 pan adapters and 4 slice receivers either. However, I was trying to help Sergey and the developers quantify what the CPU utilization might be in an extreme case. As noted, the audio is raspy when this heavily loaded. When I cut back to 2 DAX I/Q channels, 4 DAX audio channels, 4 pan adapters and 4 slice receivers, everything became smooth and nicely behaved.
Hi Everyone! Thank you for reply,
I put attention due to the in the past on versions SSDR before 1.3 I have no such CPU usage on my PC even with all DAX channel enable and 2 instance if CWskimmer.
My PC is notebook Toshiba Cosmio with
CPU i7 2,4 Ghz
RAM 32 GB
HDD- >SSD
Video-> Nvidia GTX 770m
My Ethernet is CAT6 + Internet access 300mbit/s (Gpon technology)
Some time I am using several PAN's for bands survey, in case such results of the CPU utilization, perspectives with increasing number of the applications and functionality of the SSDR rapidly push me for this discussion before 1.4 appeared.
I don't think that this effect somehow related to the PEN,, as we are know the PEN just cooling enchancement with FPGA. Jim, yea, I remember several posts concerning issue with CPU utilization and like to start it again, I think in time of encreased attention on SSDR.0 -
George, thank you !, i see even with you PC with "power of universe" not so good at all, i would like to say CPU Utilization issue can be a some blocking point and necessary to find out a way out !0
I agree, Sergey, that this much CPU usage seems unusual. If we do the math, total load is 12 x .55 x 1.8 = 11.9 virtual cores at 2.4 GHz. Since I don't have experience of older versions of SSDR, I cannot compare. I hope that version 1.5 will address the sources of high usage and raspy audio when fully loaded.0
I agree 100%, this should be adressed to FRS,
Tim can you convert it please as a problem ticket for further investigation ?0 -
We are addressing issues like this with v1.4 and will probably continue to optimize PC resource utilization with every release of SmartSDR.2
Sergey,
Try minimizing the flags in all the slices by clicking on the slice letters. I've seen this help on laptops I've run with SSDR. My issue seemed to be related to GPU layering and shading.
Put this suggestion in the "reportable curiousity" category if it helps, and random noise if it doesn't.
Hi Asher, did some screen shots at morning before starting with business day :-), i think you are right in general regarding GPU layering / shading, flags of clices has minimum impact, but the "Left Menu" and "Transmit Control Panel" from the right, what i assume just shadow a work zone of the PAN. Of course some variation with CPU utilization exist - depends on the others processes and apps , but i make a screen shots in some 10th secs after switching to the Task manager.
I guess it will be helpfull for FRS too.
i think the time now to think abt dockable GUI in SSDR ? This is also will be helpfull for users who would like to rearrange apps on the screen in other proportion.1 -
Sergey, My new tests with various configurations of slice flags on and off as well as slice controls on and off show significant reduction in CPU load. I don't think that is surprising if we consider the additional tasks being opened. My conclusion for now is that when the 6700 is maxed out with all 8 panafalls, 8 slice receivers, 4 DAX IQ channels and 8 DAX RX/TX channels busy this pretty much consumes the full capabilities of a quad core i7 fully multithreaded running at 3.4 GHz.0
- 337 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 18 Aurora
- 188 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
