CWX with Break-In turned off still unkeys between characters. Is this normal?
WA6FXT Mike
See the title!
Hi Mike,
It sounds like you may be describing a low setting of the CWX delay setting.....
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
"Break-in" only determines whether the rig keys itself upon pressing the key or whether you need to activate a PTT or footswitch before it will transmit. The delay is set as per Al's post above for CWX and on the CW panel for the keyer.1
Thanks, Al and Ken. Now that my Flex6700 is on its way back home (YEAH!!!) I'll give it a try. Your ideas sound right, thanks.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
