CWX with Break-In turned off still unkeys between characters. Is this normal?
WA6FXT Mike
See the title!
Hi Mike,
It sounds like you may be describing a low setting of the CWX delay setting.....
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
"Break-in" only determines whether the rig keys itself upon pressing the key or whether you need to activate a PTT or footswitch before it will transmit. The delay is set as per Al's post above for CWX and on the CW panel for the keyer.1
Thanks, Al and Ken. Now that my Flex6700 is on its way back home (YEAH!!!) I'll give it a try. Your ideas sound right, thanks.
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
