waterfal of the dm780 stops
on5po
hello I have 3 screens
the first with logbook and cluster,
the second with Flex
the third with DM780
when I move of the screen of the flex to the dm780 some time has the horizontal
the waterfall stops, I must wait some second so that it functions
who could tell me the reason and the solution so that it doesn't arrive anymore
I have flex 6300, I7 with 12 Gbs ram,Win 7 64 bit, hrd 6.2.73.303,
Thank you for your help
on5po, Janny
on5po, Janny
Should work fine. That's what I use with one exception. Use DDUTIL 3.x as your control point instead of the HRD Set up DDUTIL and hook it to cat in flex and it will the run the HRD server and just open up logbook and dm780 and you will not need the rig control piece on DM 780 Solved the same issues for me Hope this helps Mike N9DFD0
Janny
I am sure its related somehow to your graphics card or monitor.
For the monitor that has the lines, how is it connected to your graphics card>
What type of graphic card are you using?
730 -
I agree. 100% with a mike Use DDUTIL instead of HRD as your rig control interface. Much more stable interface1
hello, I have two cards graphics msi n250GTS, twin frozr 1G
as there were only two connected for screen, I have place a second card, for the third screen,
I use DDutil 3.0.9.03
I have a similar set-up and I have noticed, at times, that PSK Reporter (if it is engaged on DM-780) can delay the program when it is sending info to the server. See if this option is on in DM-780.0
This should really be submitted to HRD support. They have a FLEX-6300 so that they can do problem analysis to find root cause.0
Hello, Mike, I use ddutil well, I only open dm780 and (logbook + cluster)
Janny0 -
I exclusively use HRD v6.2 with 3 monitors and the F-6700; and have not had and issue.
Check your video card as previously mentioned: I have photos of the complete HRD and Flex working setup available.
Hello Mike
the communication between dm780et the logbook and cluster stop also in same time
Janny0 -
Hello,
also have in even time the communication between DM780, logbook and cluster that stop I don't see what I owe check has my cards video, she/it seems well to function
do I believe to have chosen cards of quality or are the cards necessary then special, but which?
73, Janny0 -
Did you check the PSK Reporter issue I mentioned above?0
Hello Jon,
Sorry, I don't understand what you want to explain me, can show me to you by print screen thank you
73,janny
Jon,
I believe to understand this
i think thats a bug in dm780
I had to back off to the 294 which is the the release version and had no problems after that.
Pat
Janny, Yes and it looks like it is unchecked for enable updates - so not the problem. I agree with Tim, drop a line to the HRD folks. They can remote in and look at your set-up.
Thank you, has all, I have it make, I am going to wait for the answer
on5po,Janny0 -
Hello,
after having visited the HRD forum, the problem would be suppressed as using minideluxe has the place of DDutil your opinion, thank you
who uses flex 6300 with HRD
Janny
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
