PTT and front LED not in sync
Dave - WB5NHL
Why chasing FT4TA I've noticed an interesting item regarding PTT and the front LED while using CWX When I use the function keys to transmit a stored message, the front LED would switch to red indicating transmit but then would almost immediately switch back to blue even though the message continues to be transmitted properly.
It would seem the led should be red as long as the transmitter/ptt is on.
I'm guessing the led is red while the message is being load into the transmit buffer then switches back to blue.
I have recently noticed the same issue when using an external keyer. I think this is new behavior. Have found that if the break in delay is set between 0 and 44 the red LED stays on for the entire transmission. Anything more than that - red for a second or two then back to blue until delay times out and another keying starts the cycle over again. Strange! 73, Tom K1FR0
I have entered this problem report into our bug tracker for additional investigation. Thank you for the defect report.
Which version of SmartSDR are you running?0
1.3.8.47 Just tried it again same behavior CWX @ 28 wpm with my call as F3 LED lights for about 1 sec for so then turns blue Also I have GPS module if that makes a difference.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
