S-meter funkyness
DrTeeth
Not a biggie, but recently I noticed that my S meter sometimes reads 9 + 60dB with backgound noise only. The noise level is constant and no way that bad. If I change band and then back again, it reads its 'normal' level. Once reset, it stays set. The +60 reading is on first starting SSDR IIRC.
I tend to turn on my PC and sometimes can leave it a while before loading SSDR and using the radio. This is the main situation when I notice the most little issues with DAX etc.
Guy
Did you try pecking on the meter?
) 0 -
Hi Steve
Do you mean clicking on it? Is this a known issue or something I have missed?
Sorry....I was attempting humor. Pecking on stuck meters used to be the cure for the needle stuck at max.
I haven't heard of this issue before....Seriously.
Changing bands does activate relays so let's hope it isn't a bad relay.
Steve N4LQ1 -
Ah, 'two peoples separated by a common language' as they say. You got me to smile at it anyway.
With best wishes from a cold and icy London.
- 636 The Flea Market
- 144 SmartSDR+
- 431 SmartSDR for Mac
- 261 SmartSDR CAT
- 199 DAX
- 46 Aurora
- 957 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
