RF on 6300 powered speaker output?
N7CXI
N7CXI Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
Is anyone else experiencing the issue of RF on the 6300's powered speaker output?
Using a Bird dummy load and Mix 31 beads on all coax and audio cables, I'm still getting RF into the line input of a powered PA speaker I'm currently using with the radio.
Since the level of the interference goes up and down with the PA's volume control, it appears the RF is being rectified in the PA mixing buffer amp ahead of the main volume control. While I may be able to fix it by opening up the PA and bypassing the inputs with .01 or thereabouts caps, I'm curious if anyone else has seen this happen, and if there's an easy fix.
I haven't had time to open the PA and put a scope on the input to see how much RF "fuzz" is on it. That would be a direct indicator.
... and for what it's worth, I don't experience the issue using the same gear and cabling with several other radios, just the 6300.
Jim N7CXI
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    ... but now that I've written it down,  it occurs to me that it's also possible that the RF is being rectified *inside* the 6300, and is superimposed on the powered speaker output. Guess I'd better unpack the scope. Considering that we're still recovering from a move, it's somewhat miraculous that I know what box its in...
  • Jon_KF2E
    Jon_KF2E Member ✭✭
    edited July 2018
    Jim,
    My experience with Flex radios has always shown them to be sensitive to RF. Is the speaker you are using RF shielded? I'm using Bose Companion 2 speakers and get no RF interference. I also have a non-shielded set of speakers hooked to another computer in the shack and they often squalk when I operate with high power.
    Jon...kf2e
  • Gary Wise
    Gary Wise Member ✭✭
    edited September 2015
    I have a new 6500 and had the same problem. I solved it by using audio isolation transformers in between the radio and the powered speakers.
    As the speakers I have use RCA jacks for the input, I used a preassembled isolator cable made for car stereo systems ( used between preamp level outputs from a head unit and a power amp input). Works like a charm.
    Gary - W8EEY
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    Hi Jon,
    The speaker isn't shielded, no. What is interesting, though is that I get the "RF" (assuming it is that) in the audio even with the 6300 connected to a Bird Termaline dummy load with a known good cable. I can't imagine the 6300 being THAT sensitive to external RF... :-)
    Jim N7CXI
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    Hi Gary,
    Once I know more about the nature of the problem, I'll put packaged transformers on the list for possible fixes.
    I haven't been using the 6300 lately, but the issue just popped into my head today and I thought I'd ask about it here. It's a strange one. It doesn't seem to matter much what frequency I use, what antenna, a dummy load or what if any amplifier. Given how unlikely that all sounds I'll try to look into it over the next few days. Too darned busy...
    Jim N7CXI
  • Gary Wise
    Gary Wise Member ✭✭
    In my case, my ham shack is on the 2nd floor, so I have a hard time obtaining a good RF ground. You didn't say if you were able to ground the radio, and this too might help your situation.
    Good luck!
    Gary - W8EEY
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    The shack is part of my office in the daylight basement. The RF ground is better or worse depending on frequency, but I'm still trying to figure out how it happens when driving a dummy load... ;-)
    Jim N7CXI
  • David-N5PSM
    David-N5PSM Member ✭✭
    edited August 2018
    I have solved this one!     Power the speaker from a isolated power supply and see if it goes away.    when the problem went away on my 6300 I found that it was a ground loop from the power to the speakers and the ground of the 3.5mm plug.  I added 600ohm isolation transformers inline to the speakers and no more problem.......David N5PSM
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    Thanks, David.
    Good find on the power supply!  I'll try to find a 120-120V isolation transformer in my junk and give that a try.
    Somewhere in the boxes I should have one or more Jensen transformers left over from a previous life, if that turns out to be the problem.
    Jim N7CXI
  • Jim  KJ7S
    Jim KJ7S Member ✭✭
    edited January 2020
    My experience from the upgrade I did from the 5000 to the 6300 is this.. I was getting some rf in to my Altec Lansing computer speakers even though I had "most" everything grounded to a bus on the back of the shelving. One change I made recently after I installed the 6300 was ... I re-did the grounding system, installed an additional ground rod at the base of the shack, then I tied ALL of the grounds together at one point or another, meaning that I had the tower ground/rods,antenna coaxes/ground rod, ground bus (with new ground rod) AND the house common ground tied together. That seemed to stop most all of the ground loop possibilities and "stabilized"everything, for lack of a better term, which included the altec speaker system which runs off house power. And it seems a bit "Quieter". FWIW.  Jim
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    Thanks, Jim.
    It does seem that the 6300 is exceedingly sensitive, especially since I can detect rectified RF in the audio when the radio is connected directly to a quality dummy load. Also, my shack is not in the near field of any of my antennas, and my feedlines (all unbalanced) are choked to excess with Mix 31 ferrite both at the near and far ends.
    All that aside, I have yet to find enough time to do much experimentation. I should have a few 600:600 Jensen transformers in my junk, but I need to find them. RF grounding is another issue that I should address, although my experiment with the dummy load isn't encouraging.
    It's also possible that there's something wrong with this particular 6300 itself, although I'm not ready to test that as an assertion yet.
    Thanks and 73,
    Jim N7CXI
  • W7NGA
    W7NGA Member ✭✭✭
    edited January 2018
    Jim,
    Powered speakers can be problematic. I have found with my 6300 that all RF woes from my Bose Companion Series II speakers were related to poor cabling from 6300 to speaker. I replaced the stock cable with a high quality double-shielded cable and the RF problems disappeared as expected.
    best 73's
    dan W7NGA
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    Excellent point, Dan.
    I need to try a few different cables and see if that has any effect. I may be able to do that this weekend.
    Thanks!
    Jim N7CXI
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    Suggest you read my tutorial on HOW TO BUILD A QUIET STATION
    https://community.flexradio.com/flexradio/topics/how-to-build-a-quiet-station
  • np2g
    np2g Member ✭✭
    edited November 2015
    YEP its RF getting into the speakers. Fer-rites bypass or cable ................far better to figure out why then to band aid it. Collins chokes real grounds proper PL259 installs the whole enchilada .
  • Dale KB5VE
    Dale KB5VE Member ✭✭
    edited August 2018
    This problem comes up regularly, in a way I see it as a warning they have issues with the station setup. I have run every flex made and run at legal limit. I use a set os Bose companion 2 which I feel are a excellent choice but I have also run many different power speaker systems including several 5.00 cheapo hamfest finds. Over all I have had very little issue with rf on the speakers . I have no toroid on any of my cables. The issues on the cheap speakers were fixed with a toroid on the wall wart supplying the speaker. I could go through my assortment of wall warts supply's until I found one that did not need the toroid.
    So what I am saying is you might be able to put isolation transformers on them or/and toroids on leads and get the rf out but it might be you still have issues with something else. If you do not have a field strength meter (I have found this cheap cb meter I found is a valuable part of my shack) borrow one and start sniffing you setup with it. I run 1500 watts on tune with my field strength meter set to max senativity and the meter barely moves.
    I use rg 223 coax for all jumpers up to the tuner then good quality rg 213 from there on. I clean all my so so 239 and pl259 with a brass brush and a good cleaner and tighten all with a final twist with pliers. Of course good ground with one point grounding from all equipment. My ground connection is checked with a meger
    Like I said at the beginning the rf on the speaker might be light a cough telling you have a cold.
  • N7CXI
    N7CXI Member ✭✭
    edited August 2016
    Hi Dale,
    All understood, but since I get RF in the audio when transmitting directly into a Bird dummy load, I think something very basic is going on.
    I just got home for the rest of the weekend, hopefully I'll have time to look into it.
    Thanks es 73,
    Jim N7CXI
  • Dale KB5VE
    edited November 2014
    Joe wd5y had a issue with his 6500 just like yours. He was running his 6500 into his sound card doing some special eq on recieve. He had the same issues. Reset everything and reduced the gain and it went away.
  • David-N5PSM
    edited December 2016
    Been there, done that,  Ground loop,  use separate power supply ( !isolated!) to verify.
    73 de N5PSM
  • Jon_KF2E
    Jon_KF2E Member ✭✭
    Jim,
    Does the issue go away if you turn the output on the radio down to one watt? If not maybe there is some other issue than the RF.
    Jon...kf2e
  • N7CXI
    N7CXI Member ✭✭
    edited August 2018
    Friends, countrymen - the problem is resolved!
    I replaced the Astron SS-30M switching power supply I've been using all this time with a trusty dinosaur Astron VS-35M, and the RF in the powered speaker output is gone!
    Before we start with the "I told you so's", please bear in mind that three other rigs (including my Apache Labs ANAN-100D) work perfectly from that supply and environment with no ground loop or RF problems of any kind. The 6300 (as far as I can tell) cannot practically be made to work with it.
    At the end of the day, I'm just happy to not have monkey chatter in the powered speaker output, so I'm not going to pursue this any further. Consider yourself warned, though - if you want to keep your sanity, use that SS-30M on your other rigs.
    Let the speculation begin... ;-)
    Jim N7CXI
  • KY6LA_Howard
    edited January 2017
    Switching power supplies all radiate some multiples of the switching frequency. The better quality ones have internal mechanisms to adjust the radiation frequency outside of your passband It's always best to avoid using switching supplies around radios.
