Flex Control driver problem
Paul - K6HR
I'm running PowerSDR with my 5000 on an Intel i7 machine 8GB RAM W7 64bit. It's been running great for years. I recently purchased a Flex Control Knob. When the driver loads my mouse slows down to a crawl. At first I wasn't sure if it was the FC driver, so I removed the driver and the problem went away. After a day with no mouse problem I installed the Flex Control driver again, and the mouse slowed down again. I did try changing the COM port to COM30 and restarted, but the slow down persists. I have once again removed the driver and my mouse is working again. Any ideas will be greatly appreciated.
First if your using a USB hub this will happen. If not then simply try a different port. If that does not do it check to make sure they are not using IRQ in you computer.0
Is by chance your mouse a USB device? If so then you are probably using the same USB controller for both. Try moving the mouse to a different USB port.0
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
