why does it take up too two minutes for the radio to turn off when the power button is pushed
James Kennedy-WU5E
Member ✭✭✭
When powering down my radio (6500) it takes up too two minutes for the radio to turn off, one I swear it took 5 minutes. anyone else see the same thing?
thanks Jim WU5E
It's Linux doing its closing things.0
Windows 7 - 8 seconds from button push. PC remaining on.
Ned, K1NJ
I'm seeing it on my 6700 too! Linux must b pretty busy lately... 6700 shut down fast until lately. Also radio stays active after I exit SSDR. Will try power off, unplug, power on while holding ok button tomorrow in an attempt to clear that issue.0
I noticed that the latest update does this. Up to a minute on my 6300 after pressing the power button.0
Please read my reply in this previous post https://community.flexradio.com/flexradio/topics/shutdown-issue-maybe0
Still rather annoying. When I've finished in the shack, I like to turn everything off, but I need to wait before I can turn off the PSU. If it's really not a problem to dump it mid closure, maybe Flex could just program it to switch off within a second or two, after flushing any cache that may exist. It would add confidence that that's ok.0
Just press and hold the power button to do a forced shutdown.1
Lain,
Are you pushing the power button and then closing the SSDR Software?
Or the other way around?
Alan
Hi Tim. Yes, i get that, in fact I could just turn off the PSU. But if it's OK to force it, then from a user perspective, it would a make sense for FR Systems to just program it to turn off. After all, if it's fine to turn off immediately, then it taking a minute or more to actually turn off, looks, with the greatest of respect, a bit of a dogs breakfast.0
press and hold worked
It will do, as it does on every computer. But do you really want to do that on every computer?0
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
