Flex 6700 v1.3.8.47 Program crashes with multiple slices using Profiles
Les W6JKA
Flex 6700 v1.3.8.47 Program crashes with multiple slices using Profiles. I stored profiles with 3 band slices and 4 band slices. Through Profile Manager If I load one profile and then another, the entire GUI program disappears and I get screen error "The Connection to the Radio was Lost. Please Reconnect." Select OK and Radio re-appears.
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
Did you receive the file I sent you re profiles?0
Les,
Thanks for the Profiles export, will push to Engineering for evaluation .0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
