Flex 6700 v1.3.8.47 Program crashes with multiple slices using Profiles
Les W6JKA
Les W6JKA Member ✭✭
edited March 2018 in SmartSDR for Windows
Flex 6700 v1.3.8.47 Program crashes with multiple slices using Profiles. I stored  profiles with 3 band slices and 4 band slices. Through Profile Manager If I load one profile and then another, the entire GUI program disappears and I get screen error "The Connection to the Radio was Lost. Please Reconnect." Select OK and Radio re-appears.
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • Les W6JKA
    Les W6JKA Member ✭✭
    edited October 2014
    Did you receive the file I sent you re profiles?
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    Les,
    Thanks for the Profiles export,  will push to Engineering for evaluation .
