Flex 6000 Series headphones impedance
K3HEX
I'm looking to get a good pair of studio headphones to plug into the 1/4" jack on the front of my 6300, but can't seem to find an answer for this anywhere in the technical docs. What is the nominal and range of impedance for the front panel headphone jack?
73 de K3HEX
73 de K3HEX
I don't know the impedance but I have a pair of Radiosport headphones that I use - they beat my Heil ProSet hands down. I don't use headphones a lot but when I do, it's usually a soft DX signal that I really need to concentrate on.
http://www.arlancommunications.com/products/amateurRadio/radioSport/Headsets.asp
The Grado SR60's are very very good on ear headphones. I think you could pay over a thousand dollars to get something equivalent to them. They are much cheaper than that, check out Amazon. I think the reason they sound so good is Mr.Grado listens to them to judge them, instead you using test gear and looking for good specs.
Dan0 -
I've been using the Heil Pro Set 3 on my 5000 and 6500 for the last 2 years. They do require an adapter for 1/4 in. They are excellent.0
Only published spec I have seen from Flex for the 6000 series is:
<Headphone output : 16 Ohm Minimum Load @ 21mw >
Almost all audo output and headphones these days are low impedance, so as to work with low power solid state devices. It is very rare to see anything higher than this in modern electronic devices. The exceptions to this are some audiophile targeted devices. I use a Bose headset with switchable input on the low setting.0
I'm using a Heil Proset 5 (HC-5 Element) with my Flex 6300. No outboard audio processing. I get very good audio reports. The headset is very comfortable to wear for long periods.
I'm in Kansas and I spoke with a ham (W1AEX - Bob) in Connecticut. He videoed a portion of our conversation. He was using an Anan 100 connected via PowerSDR. You can make your own opinion of my Heil ProSet 5.
https://www.youtube.com/watch?v=PiY3h3Wkw_4
Sounds pretty good. What TX EQ settings are you using on the 6300?
Any processing or DEXP?
The settings I use for AM are as below.
Have had a long list of headphones. Active noise cancelling phones will take out air
conditioner noise, blowers, lawnmowers, etc. without feeling like your head is in a clamp.
I use Bose, very comfortable.
Ned, K1NJ
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
