DAX activation for transmit
Just upgraded SSDR to 1.3.8. All seemed well, but the rig would key and no power would be produced from my data programs. Much head-scratching and swearing later, it turned out the DAX button in the transmit panel (P/CW tab) had become deselected. I don't know if that happened during the upgrade as I never (knowingly) turn it off.
Maybe another senior moment? Just posting this here in case it helps somebody.
I had the same problem about a week ago.
It's not obvious when you need screen real estate and have part of the DAX Control Panel covered.
I routinely saw this issue with v1.3.0. I normally leave my 6700 on 24/7. Often in the morning when I go to check into the Indiana Digital Traffic Net , I will have no output. Problem is always that TX on DAX1 has become deselected.
73, Ray, K9DUR
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
