(6300) 6M preamp == 160m attenuator?
N7CXI
I was working 160m tonight and decided to open a slice on 6m, to see if I could hear any auroral activity on my 160m antennal.
I noticed that when I created the "B" slice and changed to 6m, my 160m signals dropped. I confirmed this by turning off the preamp in the 6m slice - the 160m signals in slice "A" came back up to normal strength.
I think I understand what it's doing, but is there a way around it? I'm going to guess not, since we are after all talking about one set of RX hardware here.
Jim,
One thing that happens when you have only one slice open is that there is a band pass filer inline before the SCU. When you open a slice on a different band, that band pass filter is switched out and the SCU is operated in "WIDE" mode ( note the "WIDE" indicator in the upper right of the panadapter ). A second thing that happens when you turn on a preamp is that the gain in WIDE mode is intentionally not flat across the spectrum.. There will be more gain at 6 m where it is likely needed and less gain at 160 where it is likely almost never needed and could lead to intermod on strong 160 m signals.
AL, K0VM
Al, I thought the 6300 lacks BPF's; is this wrong? And, I bet FRS chose coupling caps for the preamp that roll off the gain at lower freq's, maybe? 73, w5xz, dan
The 6300 preamp low frequency attenuation was already discussed by FRS staff in another thread Search for it0
No doubt, but searching for it using most combinations of those words didn't find it.
The point of my original post is that operating 160m *and* monitoring 10 or 6m for weak signal openings in a different slice appears to be impossible because of design choice. There may indeed be more use cases where it does work in a beneficial way, this is one case where it doesn't.
--jim
Thanks. I did see that one, but I'm not sure how it's relevant to my posting.
I agree *most* HF work doesn't need a preamp with a decent (read 6000-series) receiver.
10 and 6M weak-signal work do.
That message doesn't address low-frequency attenuation either. I'd swear I saw that somewhere while
digging through messages, but can't find it now. I don't suppose it matters - it works like it works.
--jim
I can't find it either but it was a posting by Gerald (?) but it was official that the 6300 deliberately attenuated 160"when turned on preamp The search facility on the community sucks. You can only search titles and not content or authors0
Here is another official reply https://community.flexradio.com/flexradio/topics/since-v1-3-i-am-now-see-attn-on-the-screen-just-like-pre0
Got it, thanks for looking that up.
I understand *why* it works that way, and the design trade-off. Whether it's a desirable feature or not I suppose is a matter of opinion and circumstance. :-)
--jim0 -
Realistically. Unless ur living on another planet, all modern radios have too much gain at the lower ends of the spectrum The base level of atmospheric noise in even the quietest rural situation is -98 dBm on 160m The MDS of the radio is -120 dBm. So u actually need attenuation or your just amplifying noise.0
Yes, in general. If you're using a dedicated 160m receiving antenna, not so much.
Many 160m ops use things like beverages, small loops etc to improve the SNR. Most of those have a significant loss as compared to a Marconi, but a far better SNR. So subtract 20-30 dB for that and there you are - right at the edge of usable.
I said I understand why it works that way. I was just pointing out that there are use cases where it isn't desirable. I think the 6300 is a great value, but after having owned one a few weeks I'm thinking I might want to upgrade to a 6700 once I see that the software adds a few necessary features - for *my* particular needs/wants. I don't claim that my use cases are typical or should be used to sway design decisions... ;-)
--jim0
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
