CWX saved messages from external loggers
Is it possible to create a CAT/API control for each of the 12 saved messages in SSDR CWX? The saved messages are stored in the radio.
I understood from the video that there was to be a CAT and/or API command for the logger to send a specific saved message (F#) that is saved in CWX. So in logger you would just put that command in the macro, such as {CAT1ASC SWT31;} (the SWT31; is a switch emulation command that Elecraft uses to accomplish the same thing). So if FRS had a command like CWM1 - CWM12; for CW Message 1-12 then that would go in the logger CW Macro.
I worked a little with N4PY and his Pegasus Plus program. It can provide a link from
N1MM, N1MM +, and N3FJP via their winkey utilities to key the 6000 from the logger cw
interface. The winkey utilities in the loggers must be set up with a com pair to Peg. Plus
and with a little effort will work. The N3FJP contest logs look like they may work too, but
I've not tested them. Carl would be happy to help with any of this. He uses the Flex API
to communicate directly to the 6000. The loggers use a comm pair (smCAT or VSP)
to communicate to Peg. Plus.
Good Luck,
Ned, K1NJ
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
