PTT Sticks when using VOX
Ken - NM9P
Member ✭✭✭
Here is a new one that I just discovered.
on my 6500, using the latest 1.3 software.
If I am using VOX and push the PTT footswitch while talking and then let up on it, the PTT remains locked in TX.
I must turn the VOX button off for the rig to return to RX.
This happened very shortly after I had powered the rig up after a total power down (power supply off overnight,) and loading up one of my many Global Profiles.
I have repeated the effect several times. Has anyone else experienced this?
YES I have see the same thing, since unplugging the foot switch and going direct wire to the radio or using VOX it had not occurred again. SETUP Heil PR-20 with a HBA or wired direct.
Jim
WU5E
Hi Ken,
I confirm the same problem here. Turn VOX on, talk to activate VOX, push and release PTT (my PTT is through pin 14 on the rear accessory connector) while VOX is activated, and the only way to get out of TX is to turn VOX off.
Flex 6700 with 1.3.0.116 client software, 1.3.0.41 hardware software. :-)
I have written this up as a defect for further investigation. Thanks for the report.0
- 636 The Flea Market
- 144 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
