Cat virtual port gone
Ian1
If a software crash occurs in SDR or Cats sometimes Cat will delete all created Virtual Ports and not allow the creation of a new port. Reboots of both computer and or radio do not fix the problem. I find I must uninstall smart SDR and all associated software then reinstall and all is fixed. I'm running version 8.1 of windows anyone have any thoughts?
Unrelated problem with HRD I worked with Rick owner and developer of HRD to get main interface running no luck I have the Logbook working very stable but DM780 only able to receive.
Any help with CAT would be appreciated. I do also notice that if the radio is started before the computer CAT starts 1st in extensions and this will cause some conflicts with ports on startup easy fix is let computer start up 1st then start radio.
Ian
KM4CQG
Ian
KM4CQG
I had similar problems with past versions. In the end I had to delete some ghost ports as detailed in one of Tim's papers in the knowledge base. I set the Flex Control to Com 30 as recommended. So far so good. Andrew0
At one of our 6700's we have a similar problem. Most of the time , we loose all ports in CAT as soon as the PC is shut down and restarted. Sometimes only the descriptions , PTT , DTR , RTS and Dedicated are only gone. Even the file " radios.xml " is then changed. This problem does not occur with shutting down and restarting SSDR and or SCAT , only with restarting the PC. We have maked a shortcut to the map in wich this file belongs and a copy of the good working file on the desktop to recover the normal situation without reinstalling SSDR and/or SCAT.0
Ian,
I am sure your problem is frustrating, but since I have never had the problem, I don't know what to tell you to do.
AL, K0VM
P.S. I too have reassigned the Flex control port to a higher number.
Al I agree with you.
The only problem I have encountered was caused by Microsoft updates that shut off in the middle while updating.
The problem these individuals are having may be cause by their installation or misconfiguration of the software. Or just not following the instructions.
My only I advise that I can suggest is "READ THE MANUAL" and follow the instructions.
Thanks Guys
I am going to try and use the High number Virtual Port thanks for all the Help guys.
Ian
- 379 Community Topics
- 631 The Flea Market
- 122 SmartSDR+
- 193 DAX
- 39 Aurora
- 263 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
