SSDR CAT ehancement (like vspe splitter)
I have reduced my fiddling around try to figure out which rig control port and which PTT port is available by combining SSDR CAT with the VSPE that used with the F5k. Also reduces my forgetting which ports matched which when the numbers get to 10 (Senior problem - CRS!).
My serial port arrangement is now as listed in ascending port #'s:
1 - GPS rcvr (Actually I use VSPE to put it on ethernet port 3292 for use around the house).
2, 3 - Physical ports on PC
4 - Flex Control Knob (It usually wants this one anyway!)
5 - SSDR Rig Control cat commands ( NOT my choice - more later!)
6 - SSDR PTT for F6500
7 - VSPE SPLITTER from port 5 - VSPE splitter ports can be assigned simultaneously to multiple programs.
8 - VSPE SPLITTER from port 8 (Same as above)
I run VSPE as a service and forget about it.
Suggestion: find out how to make SSDR CAT ports act like VSPE splitter ports.
Another suggestion: Allow us to get away from serial ports 4 and 5 in an easier manner as most of the %^&*()(*&^% mobile/HT programming software seems to step on ports 4 or 5 and then impolitely refuse to release them when they end.
Jim
W4YXU
Jim
W4YXU
Jim You do NOT need VSPE SmartCat will do it all for you Easy to move Ports 4'and 5 somewhere else Suggest you get DDUTIL to control things and keep track of ports Here are my screen shots of my setup
To move your ports 4 and 5 go into device manager
Click on the ports you want to move.
Go to properties
Then go to advanced.
Change the port number Further SmartCat will already split CAT ports to multiple programs simultaneously. Suggest you remove VSPE entirely from your system and RTFM. (Read the SmartCat Manual).0 -
Guys, the whole problem is that we need to use the "computer" to control these things. Early on, I suggested FRS to add USB drivers to the on-board Linux system, so we can control things with the RADIO, not the computer. It is going to get real troublesome to run remote, without this capability.0
"Real Troublesome to Run Remote" You Gota be kidding! I run remote 90% of the time using a simple iPad to control my 6700 base station which is hooked to a computer. The base station in La Jolla, CA is connected to a SPE Expert 2K--FA, a SteppIR MonstIR, a Yaseu DXA28000 Rotor I easily control all these remotely. You can see the control layout above. I can even raise and lower my tower remotely but I never do. So far I have made Q's from 17 different countries (I am currently in France). #18. Mallorca. Will be next week So I really do not understand why you say it would be difficult to remote?0
You're NOT running the radio remotely, you're running a computer remotely, which is running the radio locally. That is no different than what we do today with many radios. However, the Flex 6000 Series can be a true radio server; where the radio is what you're controlling; which controls the radio's peripherals (Linear, rotor, etc) That's all I meant. 73's de Mike0
I cannot see your problem. If you were running the radio remotely, you'd probably still be running a computer that would control the radio, except that the computer would be hidden in the same box as the radio <vbg>.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
