Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
I can't get PSDR to work on my computer
                    Bill-W9OL
                    Member  ✭✭
                    I tried to start PSDR Flex5K but no joy.
the windows offereing only to start the Demo would come up.
A suggestion to check the FW cable proved to be accurate as I must have been dislodged when I ran cables for the 6K.
I reinserted the FW cable and still the same thing, Just the option to start the Demo.
Still no joy so I took the suggestion to try the restore point.
Still no joy.
Nothing but the offer to start the DEMO.
Does not even indicate the radio or it's SN as being connected.
How do I fix this
Still no joy.
How do I fix this
            Bill,
 Can you start the Flex Firewire driver utility ?
 If you can't get this, you have a FireWire problem... Either the FW host adapter card/driver, the Flex FW driver or the F5K hardware itself.
 If that is OK then your master.xml file may have become corrupt.. Reset your PSDR database, and then navigate to "%appdata%RoamingFlexRadio Systems" and rename master.xml .
 AL, K0VM
            No Al.
 I can't find it....
 Can you give me the file name and suffix?
 I've been trying to find that for 2 days.
            I had a similar problem. I had 2 connectors on my FW card. One works and the other doesn't. I bought it used so I simply use the one that works now. This sounds similar.
 Jerry N9XR
            I did find it...but it's empty
 It wants me to load a file but I don't know the name of the file or where it's stored.
            I'm missing some files somewhere.
 I need to download a current install disk for the FK.
 Too many confused files due to the Restore Point return.
 hey flex, can I get the latest install disk? LOL
            Jerry, I had both working, although the 5K was powered down as I'm been trying to learn all the ins and outs of the 6K.
 Totally different situation caused me to do a Restore Point.
 I knew that RP's sometimes caused more problems and sure enough it must have really picked the PSDR to scramble.
 All I want'ed to do was check it out so I could put it up for sale.
 Definetly can't do that now...
            I can't seem to get the FW driver working...
            Bill,
 Should be at "C:Program filesFlexradioFlexradio.exe" if not, Uninstall "Flexraio 4.1xxxx" ( the Flex FW driver ) and FRS PowerSDR vxxx versions, reboot and reinstall PowerSDR 2.7.2
 You may wish to down load a fresh copy of the install package from FRS
 AL, K0VM
            The files 'seem' to be on the HD, at least I can see them when I go to that directory.
 But I don't think they are installed
 The Blue Driver screen can come up but it's empty, no driver version or anything.
 I'm sure the radio is ok
 I think that Restore point overwrote, mutilated, spindled whatever.
 Will call Flex this am...maybe they have a disk I can buy that will re-install the 5K
            Been dere, and downloaded what I thought was proper.
 Still no joy. will keep trying
            @Bill - you really need to be using the HelpDesk for your support issues like this.0
- 355 Community Topics
- 619 The Flea Market
- 8K Software
- 15 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 900 Genius Products
- 458 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 117 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 980 Third-Party Software
