What are these vertical lines on my waterfall on 40 & 20 and spikes on pan adapter also
Tony Hateley
Screen shot?0
Got a picture?
Sight unseen, I'd guess you are seeing RFI of some form - likely from a switched mode power supply either in your house or one of your neighbors.
If you can, run the radio and computer from a battery, then chop the power at the main breaker to your house. If the signals go away, pop each break, turn the main break back on and then one at a time, turn the other breakers back on. When the signals reappear, go hunting for the culprit.
If its your neighbor, try and use a directional antenna to search it down.
Once you get the neighbor's house, try the polite approach of asking them if they are getting interference on their radio or TV as you have heard signals coming from their house - and they may be due to a faulty appliance that may fail or worse, catch fire. Could you help them find it?
Don't volunteer to touch the neighbor's equipment... use the same process as suggested above to isolate where in their home its coming from.
If the neighbor isn't helpful, resort to the FCC.
Stu K6TU0 -
Tony Here is a link to my paper on how to build a quiet station https://www.dropbox.com/s/kffp92esffo3zy5/How to Build a Quiet Station V2.pdf. BTW. I agree with STU ...likely a wall wart or switching power supply0
In the uk so no help from anyone here0
Tony - agree with he others. It's RFI from other devices. Check out KY6LA's presentation, it's great. My tips are on my QRZ page. You can go absolutely mental cleaning up your home - trust me, I have. Sad thing is, then you're left with noise from your neighbors. At some point, you will have to accept some interference. Thing with the Flex Panadapters is that it's so easy to see things you might otherwise miss. On the plus side, you will get much better reception when you clean things up. Good luck, and good hunting.1
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
