I'd like to make a Y cable from my Winkeyer to the 5K and the other side to the 6K, any problem with
Bill-W9OL
Bill-W9OL Member ✭✭
edited February 2017 in FLEX-6000 Signature Series
have both a 5K  and a 6K
I'd like to make a Y cable from my WinKeyer to each Key jack.
It's looks like they are  wired differently.
Anything wrong with this idea?
  • Paul Christensen, W9AC
    Paul Christensen, W9AC Member ✭✭
    Bill,
    Since we don't have access to schematics for either Flex transceiver, it's probably safe to assume the key line for each uses a pull-up resistor to +5V or a similar low voltage.  If so, then at a minimum, you should use a steering diode on the cables connecting to each transceiver to attain reasonable isolation.   Otherwise, you're placing two differing source voltages in parallel and that's poor engineering practice.   I now fully isolate my key lines with MOSFET devices, but at one time, I would just install a 1N914/1N4148 diode inside the male RCA connectors and label them as such.
    The WinkeyerUSB has two KEY OUT lines, so you may be able to simply direct the keying to one of the two key ports.  But, I'm not sure if that's the Winkeyer device you're using -- or maybe one of the older, original kits?
    Paul, W9AC
  • Bill-W9OL
    Bill-W9OL Member ✭✭
    edited October 2016
    Yes I have the WK USB and have a 2nd port to use.
    I tried using the F5K line in the 6K and that sure sounded bad. LOL
    Guess it's wired only for the 5K.
    Will make up a new one for the WK USB and use it. Just wanted to get away from even more cables to attract rfi.
  • W9OY
    W9OY Member ✭✭
    edited September 2014
    Using the 2 port method is clearly safer since only the chosen radio will transmit
    73  W9OY
