Connection problems to WSTJ-X & DM780 with DAX 1.0.5 in SSDR 1.3
RoyS
Flex 6300, win 7 home premium, SSDR 1.3, DAX 1.0.5, HRD DM-780. WSJT-X, Realtek Audio Driver 6.0.1
From a working system to not so much. I turned my radio on this morning and now I cannot transmit from either one of my digital programs. These were working yesterday using the VOX.
I can receive ok from DAX.
My computer uses Realtek Audio and in trouble shooting, I found the following problems.
The above picture shows Audio in and out on the WSJT-X Config. page. This setup was working fine before.
In the picture below, I click on the tune button, I get the green bar indicating a tone on DAX Audio TX 1. Which is as it should be.
What is not very obvious is, this is the playback side. There should be no TX's on the playback side at all.
Inspecting the Recording side in the next picture, shows a mix of TX & RX also.
I have done all the usual trouble shooting things including uninstalling and reloading SSDR and DAX. I haven't tried to load another driver to Realtek yet.
Looking for answers,
Roy - W5TKZ
Roy - W5TKZ
When I had the same problem yesterday, I exited the DAX control panel and restarted DAX v1.0.5 from the start menu.
But you may have a different problem..
Each DAX virtual cable is a set of two ends .. One end is the RESERVED end which is always connected to the radio ( 6500 ) and can be either a Playback (RX) or a Recording (TX) endpoint. The other end of the cable is connected to the program of your choice and is never a RESERVED endpoint.
AL, K0VM0 -
Roy
Try setting the lines to stereo instead of mono and see if it makes any difference.0 -
Roy
I get a very similar result as yours.
Everything was working in DAX until today.
will report back later.
At the moment DAX is completely unreliable.
Rob
Thanks for the tip Al. Tried it but no joy.
Roy - W5TKZ0 -
One other thing to watch for is Low power output in digital modes using DAX witch is a different problem from no power output. To restore the digital mode power output,
1) If you have not already done so, save a TX profile of your digital setup
2) Select any other TX profile
3) Reselect your digital TX profile.
If you reboot the radio, or operate another mode (SSB/CW) you will have to repeater 2 & 3 above
YMMV
AL, K0VM
Thanks AL.
Roy - W5TKZ0 -
Neal, I was looking at 20 meter ssb when I got your suggestion. I switched back to digital on the SSDR and loaded WSJT-X. What a surprise! In and out worked again. Checking the config of WSJT-X, I found the Audio In to be DAX Audio RX 1 and the Audio Out to be DAX Audio TX 1. Checking the Realtek, I find the tune tone is on DAX Reserved Audio TX 1 and that is on the Recording list where it should be.
By the way, DAX Reserved Audio TX 1 does not appear in the WSJT drop down list for Audio Out, but it does appear in the drop down for Audio In. Also Stereo mode is only available in Audio Out. ???
Roy - W5TKZ
i have a 6500 since the end of May. i use it 90% on digital and have seen the power problem you are talking about but...i also operate the rig on SSB for our section traffic net and until last night it worked fine. when i tried to check into the net last night i had no output so i thought it was my Heil ProSet cable dieing again (it happens about every 2 or 3 years) so i switched to the hand mike Flex supplied but still no output. i switched to the Pro III until after the net and the only way i could clear the problem was to shut everything down and re-boot the computer. i wonder if anyone else has seen this or if it is part of the issue that Flex is investigating. 73 Happy Labor Day
Hello Don, Yes, I have seen the same problem except mine would not clear on reboot. Yesterday I called Flex and spoke with an engineer. He took over my unit and we tried different things with no joy. Also the transmit filter was allowing out of the bandpass modulation and I was getting complaints about it. Today, it is on the way back to Flex to be looked at. Wish me luck 73.
sorry to hear that Roy. i hope they find the problem quickly 73
You should set the rig spec to Kenwood TS-2000, that works well for me....
pat0 -
Same here.... and I am using VOX to key.0
I am also using TS-2000 with no problems from the start, I would suggest to run WSJT-X before HRD DM-780, I did once start HRD and WSJT-X was not able to change the frequency in my case even after closing HRD. After a fresh PC restart all was back to normal.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
