SmartSDR CAT 1.3.0.0 - unhandled exception error
PA1MC
Member ✭
New PC and new SmartSDR installlation.
Clicking on Main CAT screen gives unhandled exception error (include message below)
Running Windows 8.1 X64 on MSI H97 AC Motherboard with Intel i7 4790T
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '-1' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ListBox.ObjectCollection.get_Item(Int32 index)
at Cat.Main.lstAvailableRadios_DrawItem(Object sender, DrawItemEventArgs e)
at System.Windows.Forms.ListBox.WmReflectDrawItem(Message& m)
at System.Windows.Forms.ListBox.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Cat
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Cat.exe
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Spring.Core
Assembly Version: 1.3.2.40943
Win32 Version: 1.3.2.40943
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Spring.Core.DLL
FlexLib
Assembly Version: 1.3.0.25787
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/FlexLib.DLL
AsyncSocketsV2
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/AsyncSocketsV2.DLL
Vita
Assembly Version: 1.0.1.25787
Win32 Version: 1.0.1.0
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Vita.DLL
Flex.UiWpfFramework
Assembly Version: 1.0.1.25785
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Flex.UiWpfFramework.DLL
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/log4net.DLL
Common.Logging
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Common.Logging.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Spring.Aop
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Spring.Aop.DLL
ftvspknet
Assembly Version: 5.4.4.0
Win32 Version: 5.4.4.0
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/ftvspknet.DLL
Util
CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Util.DLL
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Marcel - PD1MVO
mscorlib
Cat
System.Drawing
System
Spring.Core
FlexLib
AsyncSocketsV2
Vita
Flex.UiWpfFramework
log4net
Common.Logging
System.Xml
Spring.Aop
ftvspknet
Util
System.Core
enabled.
For example:
<configuration>
</configuration>
Marcel - PD1MVO
I had the same issue with Smart cat after upgrade... I just rebooted the computer and all was good....
Ran into a similar situation with SmartCAT after upgrading. The new software worked well, however on putting the PC to Sleep, the PC halted the transition to Sleep and displayed a similar msg. It only happened one time and I have not seen the error msg again after multiple sleeps iterations.
PC is i5 with WIN 8.1 64 bit.
Marcel - is this problem still happening?
Hi Tim, same problem.
Also installed old version with same issue, so its seems hardware related.
Regards,
Marcel0 -
I have entered this report as a defect in our bug tracker for further investigation. Sorry for the inconvenience.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
