SmartSDR CAT 1.3.0.0 - unhandled exception error
PA1MC
PA1MC Member
edited March 2017 in SmartSDR for Windows
New PC and new SmartSDR installlation.
Clicking on Main CAT screen gives unhandled exception error (include message below)
Running Windows 8.1 X64 on MSI H97 AC Motherboard with Intel i7 4790T
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '-1' is not valid for 'index'.
Parameter name: index
   at System.Windows.Forms.ListBox.ObjectCollection.get_Item(Int32 index)
   at Cat.Main.lstAvailableRadios_DrawItem(Object sender, DrawItemEventArgs e)
   at System.Windows.Forms.ListBox.WmReflectDrawItem(Message& m)
   at System.Windows.Forms.ListBox.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Cat
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Cat.exe
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Spring.Core
    Assembly Version: 1.3.2.40943
    Win32 Version: 1.3.2.40943
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Spring.Core.DLL
FlexLib
    Assembly Version: 1.3.0.25787
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/FlexLib.DLL
AsyncSocketsV2
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/AsyncSocketsV2.DLL
Vita
    Assembly Version: 1.0.1.25787
    Win32 Version: 1.0.1.0
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Vita.DLL
Flex.UiWpfFramework
    Assembly Version: 1.0.1.25785
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Flex.UiWpfFramework.DLL
log4net
    Assembly Version: 1.2.11.0
    Win32 Version: 1.2.11.0
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/log4net.DLL
Common.Logging
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Common.Logging.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Spring.Aop
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Spring.Aop.DLL
ftvspknet
    Assembly Version: 5.4.4.0
    Win32 Version: 5.4.4.0
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/ftvspknet.DLL
Util
    CodeBase: file:///C:/Program%20Files/FlexRadio%20Systems/SmartSDR%20v1.3.0/SmartSDR%20CAT/Util.DLL
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Marcel - PD1MVO
  • John n0snx
    John n0snx Member
    edited April 2015
    I had the same issue with Smart cat after upgrade... I just rebooted the computer and all was good....
  • Ed_NZ1Q
    Ed_NZ1Q Member ✭✭
    edited March 2017
    Ran into a similar situation with SmartCAT after upgrading. The new software worked well, however on putting the PC to Sleep, the PC halted the transition to Sleep and displayed a similar msg. It only happened one time and I have not seen the error msg again after multiple sleeps iterations.
    PC is i5 with WIN 8.1 64 bit.
    edited March 2017
    Marcel - is this problem still happening?
  • PA1MC
    PA1MC Member
    edited November 2014
    Hi Tim, same problem.
    Also installed old version with same issue, so its seems hardware related.
    Regards,
    Marcel
    edited March 2017
    I have entered this report as a defect in our bug tracker for further investigation.  Sorry for the inconvenience.
