ZZSM return values are always even numbers
Tim K8XS
I am writing software to convert the smeter readings into dBm. The value will be displayed continuously is a separate box. During the development, I happened to notice that the values returned from ZZSM were always even numbers. The documented range of 0 to 260 would imply to me to mean all values, not just even values. I find this a bit odd (pun intended). Maybe this is intentional; however, past experience makes me wonder if a LSB (ie the 2^0 value) is getting truncated or masked. Just an observation.
BTW, I am giving the app the ability to have peak hold and the hold time and level of integration and sample rate are user adjustable parameters. I am writing it in VB.net using Visual Studio Express 2013.
2
I woul love to see that app!0
No problem Nick. I'll make it available to anyone who wants it.
-Tim K8XS0 -
Yes great thing. I am amassed that the smart sdr is so good and could be light years ahead of the other brands if they would just not lose what was already available in powersdr. I miss the ability to set my skin and the ability to display in a form I can see and use a real looking smeter and the display of DBM and the power out and swr in something but a funky hard to see red one. I know you can Hoover over the smeter and see DBM so why not allow you to tun it to DBM all the time. I use ddutil to get these features but why do I have to load a third party program which is available on power sdr already. I know I will now have 10 people tell me how much the love the hard to see red lines but I do not. Keep up the development.3
Thank you so eloquently stating the problem with that useless impossible to see red on black tiny analog meter.0
Totally agree.... That's why I like my BIG woodbox BOBSmeter for SSDR.... it works great and placed right it looks like it's part of SSDR
John
"During the development, I happened to notice that the values returned from ZZSM were always even numbers. The documented range of 0 to 260 would imply to me to mean all values, not just even values."
The return value from ZZSM will always be an even number due to the scaling operation that is applied to the data from the radio as the metering function in the 6000 does not return values from between 0 and 260 which is done to ensure compatibility with the previous PowerSDR ZZSM CAT command.
The Kenwood SM command compresses the S-meter into a maximum of 30 increments. The ZZSM command only compresses it into 260 increments. Neither were intended to return an exact meter readings. If you want more precision, you should dump CAT and use the API to communicate with the radio, but I suspect for just displaying S meter reading, precision to that level is not required or the error significant.
Nick,
I have a version of the program that I feel comfortable releasing. Drop me an email (K8XS on QRZ.com and I'll send you a copy).
Tim K8XS0 -
Tim,
Where do I get a copy of the API?
-Tim K8XS0 -
On its way0
On its way0
- 323 Community Topics
- 577 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
