Info on profile feature
Does anyone know where there is some documentation for the new Profile feature?
Welcome!
  • Administrator, FlexRadio Employee admin
    edited February 2018
    All features are documented In the SmartSDR for Windows Software User's Guide
    http://www.flexradio.com/downloads/smartsdr-software-users-guide-pdf/
  • Member ✭✭✭
    edited June 2020
    Tim The documentation is pretty sparse as it only describes how to save and load profiles It would be really helpful if someone could document EXACTLY which elements were saved in the Global and Transmit profiles.
  • Member ✭✭✭
    edited June 2016
    Tim, an appendix with the list of items that the Profiler will save would be helpful.
    Pat   WR1Z
  • edited May 2015
    I am finding they don't hold. They run ok for awhile and then things start to change as I switch through the profiles.
  • Member ✭✭✭
    edited December 2016
    Alan,
      I thought I saw the same thing, until I realized that I was sometimes double clicking to select a profile..  Might also be sensitive to changing from one profile to the next to qucikly.
    AL, K0VM
  • Member ✭✭✭
    edited March 2017
    The new software users guide V1.3 can be downloaded from the Flex website at SUPPORT>DOWNLOADS>FLEX6000> DOCUMENTS> half way down the list is the software users guide in German and english....
    We are working on the v1.3 German translation.  it should be available later.
  • edited September 2014
    You are right about the profiles not holding has nothing to do with double-clicking.
    I have been playing with the profiles a few days I see most of the problem with global profiles remembering sometimes but not always.
    Ed, WB2K
