Info on profile feature
Does anyone know where there is some documentation for the new Profile feature?
    edited February 2018
    All features are documented In the SmartSDR for Windows Software User's Guide
    http://www.flexradio.com/downloads/smartsdr-software-users-guide-pdf/
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    Tim The documentation is pretty sparse as it only describes how to save and load profiles It would be really helpful if someone could document EXACTLY which elements were saved in the Global and Transmit profiles.
  • Patrick
    Patrick Member ✭✭✭
    edited June 2016
    Tim, an appendix with the list of items that the Profiler will save would be helpful.
    Pat   WR1Z
  • Alan Nusso, N4BV
    edited May 2015
    I am finding they don't hold. They run ok for awhile and then things start to change as I switch through the profiles.
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited December 2016
    Alan,
      I thought I saw the same thing, until I realized that I was sometimes double clicking to select a profile..  Might also be sensitive to changing from one profile to the next to qucikly.
    AL, K0VM
  • k0eoo
    k0eoo Member ✭✭✭
    edited March 2017
    The new software users guide V1.3 can be downloaded from the Flex website at SUPPORT>DOWNLOADS>FLEX6000> DOCUMENTS> half way down the list is the software users guide in German and english....
    We are working on the v1.3 German translation.  it should be available later.
  • Edward Armstrong-WB2K
    edited September 2014
    You are right about the profiles not holding has nothing to do with double-clicking.
    I have been playing with the profiles a few days I see most of the problem with global profiles remembering sometimes but not always.
    Ed, WB2K
