Problem using Zoom In whilst using Transverter
Using a Flex 6500 Running SmartSDR ver 1.3.0.116 Hardware ver 1.3.0.41
I use a Transverter for 4 Metres which works fine, It transmits and receives ok and displays the correct frequency until I use the Zoom In feature Using the Looking Glass + Icon. When I click this Icon the display frequency jumps from 70Mhz to 112Mhz.
I can use the drag method to Zoom In and out without any problems and I can use the Zoom Out Looking Glass - Icon which is fine, but as soon as I use the Zoom In icon the transceiver displays 112Mhz.
Its not a major problem but it is there.
Any ideas ?
Peter
Peter - can you post a before and after screenshot of the panadapter so I can see the effect?0
Hi Tim, Windows won't let me paste so here are a couple of jpegs0
If you notice the after it appears to have moved the panadapter up the band giving me the option to return to my original frequency by double click to the left of the screen to return to 70.168
I also noticed that after double clicking and returning to 70.168 it had zoomed in x1
I see the problem.. I am writing this up as a defect in your bug tracker. Thank you for the screen shots, that helps soooooo much!
No problem Tim, I thought it was a bug when I came across it, it is easy to work around though.
Peter
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
