test micro with 6300
In my instance, I found the stock hand mike that came with the 6300 to work just fine. I didn't even change the settings I had in place with the Heil RCA Replica mike (Pro element and HC5) and received good responses from several stations when making direct comparisons. As expected, the hand mike wasn't quite as full as the Heil but still very good audio reports.... now without the EQ settings, that may be a different story.0
While waiting for an adapter to arrive for my Heil headset, I gave the Flex mic a try. All reports were positive with comments like perfectly fine, easy to listen to, etc.
I have the mic switch (on the back) set to #1 (flat), and the EQ set for a 1-2 dB rolloff at 125 & 250, and a presence rise of 2-6 dB from 1 to 4 kHz. 63 & 8K at -10. This is a perfectly serviceable hand mic; I don't know what all the fuss is about.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
