Configuration on MacBook Pro with Parallel Desktop
edited February 2018 in SmartSDR for Windows
Hi,
I am on holidays house, I have a MacBook Pro with Parallel Desktop, but I have a problem Flexradio, I using WiFi connection to Internet I attach my flex on Ethernet port, but Parallel Desktop not "see" a IP of Flexradio.
I need a good configuration for use Flexradio direct connect to my MBP and Wifi connection for internet.
Welcome!
  • Member ✭✭✭
    edited February 2017
    Both the radio and SSDR must be on the same sub-net.  I'm guessing your WiFi and radio are on different sub-nets.
  • Member ✭✭
    edited December 2015
    Frank,
    I guess this wil fix your issue:
    Parallels & SmartSDR
    VY 73
    Thomas
    DK1EY
  • Member ✭✭
    I try but no chance, best solution  for me at moment is Ethernet Bridge, but on Win7 no internet connection available :-(
    My flex is connect direct to LAN on my MBP as DHCP mode and assign automatic a IP 169.254. 230.22 SubMask 255.255.0.0 no router assign
    on Win7 I have only local connection , Flex have IP 169.254.8.60 and a Virtual LAN card on Win7 have 169.254.240.60 SubMask 255.255.0.0
    Please I've me an help tnx and 73
    IZ7AUH
  • Member ✭✭
    You tried this one, as K6OZY described it?
  • Member ✭✭
    edited September 2014
    yes i tried... but no work.... please tell me a ip setting from OS X and Parallel Desktop
  • Member ✭✭
  • Member ✭✭
    yes i tried... but no work.... please looking my screenshot of my full settings.
  • Member ✭✭
    Did you connect th eflex via ethernet cable with your Mac?
  • Member ✭✭
    Yes i connect directly with ethernet cable to my MBP
  • Member ✭✭
    That worked for me. I have to try it, when I am at home tonight and will come back to you as soon as I could figure it out.
  • Member ✭✭✭
    I use VMWare with two network adapters. One configured to WiFi with the other configured to Ethernet. This work perfectly for me, I have internet via WiFi and my Flex 6500 via the ethernet direct connection.  73
  • Member ✭✭
    I have VMWARE Fusion, and I have same problem, do you can send me a exactly configuration on Network tab of OSX, VMWare network configuration and Windows 7 configuration too.
    Best 73 auh
  • Member ✭✭
    Hi Frank,
    I tried it at home with Parallels Desktop and it worked as described. Sorry that I cannot help you.
    VY73
    Tom
    DK1EY
  • Member ✭✭✭
    Frank,
    No changes to OSX configuration necessary.
    Ethernet cable connected from Flex to OSX computer
    OSX WiFi connected to my local WiFi network.
    VMWare Fusion Screen shots:
    In the VM configure a second network adapter
    In the VM configuration this is 1st network adapter setting
    In the VM configuration 2nd network adapter setting
    Let me know if you have other questions.
