HOW-TO: Setup FLEX-6X00 with N1MM / CW Skimmer for multiple slice contest operating
DK1EY
Although I am not a contest operator but an excited CW enthusiast, I just wanted to try how to get most out of my two slices and tried to setup my machine to reach the following goals:
The following threads helped essentially to setup my station in terms of software:
Due to the integration of all those nice little tools, I am now able to receive CW on two different slices/bands and to spot the signals received on both bands simultaneously via CW Skimmers telnet outputs to the N1MM bandmaps for each VFO/slice. It is great to have spots on your bandmap, that your machine has heard. So you dont have to be limited to the sometimes "unworkable" spots from an online-cluster.
You can guess, what comes next: While working one contact on e.g. 40m on VFO/slice A, it is very easy to prepare the next contact on another frequency/band on VFO/slice B. In combination with a WinKeyer (in my case the NanoKeyer) that is driven by N1MM, my Flex-6300 becomes a serious contest-machine.
Assuming that you got N1MM running as described in 1., load SDR-Bridge. After installation, run the program and assign slice A to IQ1 and A, slice B to IQ2 and B and so on.
The program assigns VFO/slice A Telnet port #7310, VFO/slice B Telnet port #7320 and so on. At this point, only on one bandmap, the spots are shown.
Now the challenge was to integrate multiple Telnet ports, what - in my opinion- is not possible with N1MM alone. So: If you now run wintelnetX and load Ed - W2RF's ini-file, you just have to click once on connect, and the dream-machine will run!
That's it!
If anyone has questions, or needs help setting up something like this, do not hesitate to contact me.
VY 73
Tom
DK1EY
Many thanks to:
Ed - W2RF for solving my "single-bandmap-issue".
Jim - WD5IYT for the great HOW-TO regarding N1MM.
- Complete integration and exchange of Smart SDR, N1MM (connected to my NanoKeyer) and CW Skimmer
- Use both slices as VFO A and VFO B in N1MM SO2V-mode
- Spot my received stations via telnet onto the N1MM band maps for each VFO/slice
- Handshake between N1MM, CW Skimmer and SmartSDR
- Using N1MM Logger With SmartSDR/SmartCAT, FlexControl, and K1EL WinKeyer > General setup of N1MM for contest use.
- CW Skimmer on 3 bands... > This one led my to the complete integration.
That's it!
VY 73
Tom
DK1EY
Many thanks to:
12
Well cool! Exactly why the 6300 is looking attractive to me to switch over to for my contesting and dxing needs. Thanks for the info. Steve gw0gei0
Good Job, That was my next project. Getting N1MM synced up.
Thanks for the road map.
you may be hearing from me
I use a WinKeyer USB, but shouldn't matter.
It should be no problem, as the NanoKeyer is based on the K1EL-keyer.
Do not hesitate to contact me.
In one week you won't need the WinKeyer for N1MM. Direct support in V1.31
Hopefully you are right! I am looking forward to the SSDR enhancements with 1.3 and especially CWX.
But: Keying was not the main issue, I solved like described above.
Tom
DK1EY
Stan?? Are you talking about CWX? Not sure how that will connect to N1MM.
Or are you saying N1MM is direct to SmartSDR keying?
I haven't seen that in the N1MM messages.
Bill,
at the moment, the N1MM keys the NanoKeyer (K1EL-protocol) and the NanoKeyer keys SSDR.
If N1MM could key SSDR via CWX or another native software integrated option, an additional keyer could become dispensable.
the longer I think about Stans comment, the more ideas how to setup a lean software with native SmartSDR options evolve.
I am looking forward to the coming improvements of SSDR.
VY 73
Tom
DK1EY
I just tried it with N1MM+. It works also perfect. N1MM+ is still not able to manage multiple telnet ports at the same time. But with wintelentX it is no problem, as described above.0
I used WintelnetX also. Finally learned from Lee Sawkins that any of his nodes are connected to all the other nodes. Any node in the world. A spot on one is a spot on all. Maybe a 1000th of a second delay, but heck, I can't read that fast anyway. :-)
What is the URL for downloading N1MM+? At the usual site I get "not authorized"
73 Ed W2RF
OK, Am I the only guy who understands about 10% of this thread? I am embarrassed to say, I think I need some profound education on CW.- and how is works with SSDR. (BTW, I'm not a CW guy, but I would like to be)
RE:- Complete integration and exchange of Smart SDR, N1MM (connected to my NanoKeyer) and CW Skimmer
What is N1MM, NanoKeyer, SO2V Mode, Spotting received stations via telnet, and CW Skimmer. I am not familiar with the aforementioned...
I guess I will just take one at a time and Google it...
Alan
Hi Alan,
let's start from scratch:
I assume, you are a Flex user already. If not, please do not stop reading here. The most tools, I described in the thread will work with other CAT controlled transceivers.
To answer your questions:
N1MM+ is a proven logging tool for contesting. It sums up your contacts, shows you dupes (you want to avoid in a contest), calculates multiplicators (you want to work in a contest to gain more points), shows you a bandmap with a predefined DX cluster, tells your rotator in what direction it should turn your antenna and many more points.
Key features- ESM- Enter Send Message Mode - just press the Enter key to make a qso.
- Uses sound card for DVK but also DVK interface for W9XT and other DVK interfaces.
- Automatic CW generation (LPT and via USB to serial converter).
- Rotator control (Using N1MM Rotor, LP-Rotor or ARSWIN).
- Grayline window
- Two VFO support when using one radio, with one VFO per Bandmap.
- SO2R/SO2V support.
- Telnet cluster support - spots automatically update the bandmaps.
- Winkeyer support (Serial CW keyer by K1EL).
- Automatic beam heading and sunrise/sunset calculations.
- Spot all S&P calls locally (QSYing wipes the call and spots QSO in bandmap).
NanoKeyer: The nanoKeyer is suitable as a standalone keyer or for keying the radio via the USB port from a connected computer and your favoured contest logging software (in my cas N1MM+). By means of the K3NG firmware it can be also used as a computerless keyboard keyer by attaching a PS2-Keyboard to it.for a full feature list, please have a look at Radio Artisan: ARDUINO CW KEYER.
CW Skimmer is a software that can read out your signals (if your radio is able to put them out to your soundcard) and decode CW code. This decoded CW signals appear on a bandmap. With the help of a telnet cluster, you can push those decoded signals forward to the N1MM+ bandmaps. CW Skimmer features:- A high sensitivity CW decoding algorithm based on the methods of Bayesian statistics
- Simultaneous decoding of ALL cw signals in the receiver passband - up to 700 signals can be decoded in parallel on a 3-GHz P4 if a wideband receiver is used
- A fast waterfall display, with a resolution sufficient for reading Morse Code dots and dashes visually;
the callsigns are extracted from the decoded messages, and the traces on the waterfall are labeled with stations' callsigns - The extracted callsigns are exported as DX cluster spots via the built-in Telnet cluster server
- A DSP processor with a noise blanker, AGC, and a sharp, variable-bandwidth CW filter
- An I/Q Recorder and player.
Handshake between the above mentioned tools has to be understood as an bidirectional way of communication between the tools. If I turn my FlexControl, frequency changes will be made in CW Skimmer as well as N1MM+. Clicking on a stations call in N1MM+ will change the frequency in SSDR and CW Skimmer and so on. Got it?
I hope, my explanations can help you to understand, what powerful contest machine you can make out of your Flex with the help of those tools.
If you have any questions, please do not hesitate to contact me.
VY73
Tom
DK1EY
See the workflow on the attached screenshot. Just for your understanding, from where to where the signals flow.
That worked. Thanks!
Tom,
It appears that the SmartSDR and Skimmer VFOs are not synchronized in your screenshot. In order to get them synchronized you need to run a synchronizer like SDR-Bridge.
Otherwise this looks great.
73 Ed W2RF
Hi Ed,
normally, I run SDR-Bridge (as you can read in the initial posting). I dont know, why the symbol does not appear (although the Skimmer windows were started by SDR-Bridge.
A question regarding SDR-Bridge. Is it possible to restore settings? Everytime I startup SDR-Bridge, I have to do the few clicks to set it up right.
Could you post a screenshot regarding the settings in SDR-Bridge to synchronize slices with skimmers?
VY73
Tom
DK1EY0 -
Tom,
Thanks for the reply! I have a long way to go to comprehend/implement this process.
Alan
It is a pleasure to share knowledge, that I am happy with. If you have questions, just contact me.
VY73
Tom
DK1EY2 -
Tom,
It looks like you have everything set up properly, and that you used SDR-Bridge to open the Skimmers. At that point the Skimmers would be synchronized with SmartSDR. Then you closed SDR-Bridge, perhaps by accident. After that the Skimmers lost synchronization with SmartSDR.
Simply start SDR-Bridge and everything should be AOK!
SDR-Bridge remembers all settings. I don't know why you are having to do clicks. Please post more info!
73 Ed W2RF0 -
I can confirm this:
Especially the frequency settings in the skimmer windows do not show the right values, even with SDR-Bridge open (as mentioned before). I start the skimmers via SDR-Bridge. But that frequency issue is no issue for me, because I can move the skimmer-bandmap up and down and see the signals. Only the alignment of the active section does not synchronize properly. Due to the fact that I let all spots appear on the N1MM+ bandmaps the skimmers bandmap is not of interest for me.
I tried again: The SDR-Bridge settings are not completely remembered after shutting down the program and reopening it. The telnet tab settings and the skimmer>server tabs settings have not been stored.
After shutting down and reopening just SDR-Bridge, the frequencies shown in the skimmer windows do not change to the slices frequencies.
VY 73
Tom
DK1EY
If Skimmer is not synchronized with SmartSDR, the frequencies of the spots sent to N1MM will be incorrect!
It is correct that the telnet tab is not stored because it is not implemented. I am not sure about the skimmer server tab. I don't think you are using it anyway, are you?
After reopening SDR-Bridge, allow a little time for the program to get organized. Then you need to move the SmartSDR panadapters with the hand cursor. Just shake them a bit to restore synchronization.
If SDR-Bridge is working properly, frequencies are synchronized. If not, please post a screen shot showing the SDR-Bridge panel, The Skimmer windows, And SmartSDR so I can analyze the situation.
73 Ed W2RF0 -
Ed,
please take a look at the attached screenshot. Everything but the IQ output in the DAX control panel looks fine, right?
Do you have an idea, why it has an offset in the output frequencies?
VY 73
Tom
DK1EY
The DAX IQ panel display is of the center frequency of the Panadapters. This is correct.
You can save CPU bu turning off the two audio DAX channels. They aren't needed.
Glad everything is working properly. Enjoy!
73 Ed W2RF0 -
Hi Ed!
How to you connect audio into the skimmer? DAX RX1 does not work for me. My PC is well oversized for the flex, so cpu usage does not count
But I recognize, that the connection between the Flex and skimmer via SDR-Bridge works just in one direction: Click onto the skimmer, frequency change on SSDR. Moving SSDRs slice does not affeact anything in SDR-Bridge. Any ideas?
73 Tom DK1EY0 -
Skimmer uses I/Q audio....Activate that via the DAX pull down on the left side of the Panadapter. Use DAX I/O 1 or 2, but be sure that the channel definitions match...0
O am getting the following error when trying to set up.
Cannot negotiate input format with 05 DAX IQ RX1: error 1169
Steven,
where do you get this message? I mean in which of the above mentioned steps?
VY73
Thomas
DK1EY0 -
i get the message when I hit the radio button in skimmer to turn it on
in preparation for the next weekend
Steven, have you assigned it that way? Slice to be Skimmed hast to have the same settings in CW Skimmer and in SmartSDR
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
