Configuration on MacBook Pro with Parallel Desktop
iz7auh
Member ✭✭✭
Hi,
I am on holidays house, I have a MacBook Pro with Parallel Desktop, but I have a problem Flexradio, I using WiFi connection to Internet I attach my flex on Ethernet port, but Parallel Desktop not "see" a IP of Flexradio.
I need a good configuration for use Flexradio direct connect to my MBP and Wifi connection for internet.
Both the radio and SSDR must be on the same sub-net. I'm guessing your WiFi and radio are on different sub-nets.0
I try but no chance, best solution for me at moment is Ethernet Bridge, but on Win7 no internet connection available :-(
My flex is connect direct to LAN on my MBP as DHCP mode and assign automatic a IP 169.254. 230.22 SubMask 255.255.0.0 no router assign
on Win7 I have only local connection , Flex have IP 169.254.8.60 and a Virtual LAN card on Win7 have 169.254.240.60 SubMask 255.255.0.0
Please I've me an help tnx and 73
IZ7AUH0 -
You tried this one, as K6OZY described it?
yes i tried... but no work.... please tell me a ip setting from OS X and Parallel Desktop0
yes i tried... but no work.... please looking my screenshot of my full settings.
Did you connect th eflex via ethernet cable with your Mac?0
Yes i connect directly with ethernet cable to my MBP0
That worked for me. I have to try it, when I am at home tonight and will come back to you as soon as I could figure it out.0
I use VMWare with two network adapters. One configured to WiFi with the other configured to Ethernet. This work perfectly for me, I have internet via WiFi and my Flex 6500 via the ethernet direct connection. 730
I have VMWARE Fusion, and I have same problem, do you can send me a exactly configuration on Network tab of OSX, VMWare network configuration and Windows 7 configuration too.
Best 73 auh
Hi Frank,
I tried it at home with Parallels Desktop and it worked as described. Sorry that I cannot help you.
VY73
Tom
DK1EY0 -
Frank,
No changes to OSX configuration necessary.
Ethernet cable connected from Flex to OSX computer
OSX WiFi connected to my local WiFi network.
VMWare Fusion Screen shots:
In the VM configure a second network adapter
In the VM configuration this is 1st network adapter setting
In the VM configuration 2nd network adapter setting
Let me know if you have other questions.
730
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
