The VOX doesn't function,in my 6300, that has the solution
Hello
The VOX doesn't function, that has the solution
tks 73
Janny
Welcome!
  • Member ✭✭
    edited January 2018
    Make sure that the PTT switch on your microphone is properly wired and not breaking the microphone element line as well as switching the PTT.
  • Member ✭✭
    edited January 2017
    hello Rick,
    the ptt functions, well in normal use   when I want to use the VOX, I light the button vox on smart, nothing doesn't operate a xmit
    Janny
  • Member ✭✭
    edited January 2018
    What kind of mike are you using?  If it's the original Flex handheld I don't have any other ideas., but some other types of microphones actually break the audio line as well as keying the PTT, in whch case it would work fine in normal PTT use, but would not work on VOX.
  • Member ✭✭✭
    edited June 2020
    VOX may not work if you also have DAX activated. Check that button. Also, how are you adjusting the VOX level slider? What mike are you using?
  • Member ✭✭
    edited January 2017
    Hello Rick
    I would like to use a HEIL procet elite has vec the vox
    Janny
  • Member ✭✭
    edited January 2017
    Hello,Ken
      I would like to use a HEIL proset elite has vec the vox, I also tried all the control, delay, don't function
    Janny
  • Member
    edited December 2016
    Make sure the DAX button is OFF, I got the tip from Dudley and it go my VOX working.
    Phill
  • Member ✭✭
    edited January 2017
    Dear Phill,
    Thank you, I had not understood well,  now with the button dax eteind, it functions
    thank you very much
    Janny
