The VOX doesn't function,in my 6300, that has the solution
on5po
Hello
The VOX doesn't function, that has the solution
tks 73
Janny
tks 73
Janny
Make sure that the PTT switch on your microphone is properly wired and not breaking the microphone element line as well as switching the PTT.0
hello Rick,
the ptt functions, well in normal use when I want to use the VOX, I light the button vox on smart, nothing doesn't operate a xmit
Janny0 -
What kind of mike are you using? If it's the original Flex handheld I don't have any other ideas., but some other types of microphones actually break the audio line as well as keying the PTT, in whch case it would work fine in normal PTT use, but would not work on VOX.0
VOX may not work if you also have DAX activated. Check that button. Also, how are you adjusting the VOX level slider? What mike are you using?2
Hello Rick
I would like to use a HEIL procet elite has vec the vox
Janny0 -
Hello,Ken
I would like to use a HEIL proset elite has vec the vox, I also tried all the control, delay, don't function
Janny0 -
Make sure the DAX button is OFF, I got the tip from Dudley and it go my VOX working.
Phill
Dear Phill,
Thank you, I had not understood well, now with the button dax eteind, it functions
thank you very much
Janny0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
