Mac mini And Bootcamp
Bob G   W1GLV
Bob G W1GLV Member ✭✭
Cannot get bootcamp to find my network. Everything works great in Parallels. I want to check both out and make up my mind as to which one to use.
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    edited August 2014
    More than likely it means that the driver wasn't loaded properly when you installed it. Check the device manager and see if its loaded correctly.
  • Jay -- N0FB
    Jay -- N0FB Member ✭✭
    edited June 2020
    Did you use the Bootcamp assistant in theMac OSX to create your windows environment?
  • Bob G   W1GLV
    edited December 2016
    Yes, I did. I'm new to Mac stuff. The Bootcamp Wizard has three choices. One to create install software for a USB memory stick. One to get all of the drivers and necessary software to make things work. One to install Windows in the Bootcamp partition. I did two of them because somewhere in the instruction it said item #2 was not necessary since the install software had all the drivers and necessary Apple software to make Windows work. That's not the case I believe.
    I've since deleted the Bootcamp partition in favor of Parallels software. SSDR runs very nicely with Parallels. I may retry Bootcamp at a later date. Thanks for responding.
  • Reggie-k6xr
    Reggie-k6xr Member ✭✭
    edited July 2016
    I believe you have to use "bridge" in networks configuration while using parallels. I had same problem until I selected bridge the networks
  • Yancy Lucas
    Yancy Lucas Member
    edited September 2014
    I am using Parallels and everything works very well.
  • K6OZY
    K6OZY Member ✭✭✭
    edited February 2017
