Contest Workflow
My own frustration with SSDR is contest workflow… having to move the mouse to adjust the radio which results in losing mouse focus on the contest logging software … It really slows down the workflow and more seriously results in errors if you lose eye hand synch (which I am prone to do)
I must say that Contest Workflow is helped a lot with the FlexControl Knob and the K6TU Flex Ipad App and DDUTIL. But even those useful tools, while still keeping focus on the contesting software, still take your fingers off the keyboard onto the mouse or iPad or FlexControl and back...
The real solution is to integrate SSDR into a contest logging program…so that virtually everything you need to do in a contest can be done without taking your fingers off the keyboard.
Until something like that is developed, I see that Flex will continue to be an also ran in the contest world...
I use Wizmouse. It's a free app that automatically focuses your mouse on whatever window it lands on. No click is needed to focus. I can jump from one monitor to the other without clicking to focus. Works with Win 7 or 8 and more.
Love it.
http://antibody-software.com/web/software/software/wizmouse-makes-your-mouse-wheel-work-on-the-windo...
Another gadget is the Logitec 705 mouse. The wheel is weighted. You can flip and spin the thing and it coast like the knob on a big rig. If you don't like that, push a button and it becomes a normal mouse with drag.
N4LQ Steve
Keeping focus is a problem. Anything I do that controls the radio from the logging program works just like with a conventional radio. Having a second monitor allows me to see the FLEX without logging windows covering it up. The FLEX Control allows me to tune the radio and still be on the logger with keyboard, same as a conventional radio. If I click tune with the mouse, a double click returns focus back to logging program. Sometimes, however, I find myself in the wrong place, and I have to refocus my efforts to the logging program. A partial solution might be to make more features programmable by the FLEX control. In PowerSDR, one could program the buttons for several functions, such as step filter BW up and down. Longer term solutions might be a bigger FLEX control with more buttons, making it closer to a conventional radio front panel, or a FLEX control with a mouse built in! iPad or Win Tablet app could do the same thing without dedicated hardware. Do everything from the keyboard? That would be great, but I'd run out of keys! --Mike, WV2ZOW0
Its every easy to enable mouse focus by hovering in W7
You can enable a mouse mode in Windows 7 or Vista where just hovering over a window with the mouse will switch to that window. In the old days, this used to be called the XWindows mode, and was enabled through TweakUI, but now it’s built right into Control Panel for everybody to use.To turn this setting on, just type “mouse works” into the search box in the Control Panel, and you should see an item called “Change how your mouse works”.
In this screen, scroll down and find the checkbox for “Activate a window by hovering over it with the mouse”.
No need for external programs..
BUT it still does not solve the issue of lifting your hand off the keyboard for contesting
What do you use for contest logging software?
I agree the mouse causes most of the issues and I understand why some people say you need a second computer to log. When your running a frequency it is great as you make very few adjustments to the radio, but search and pounce is more complex
For field day I did use a logging computer connected to the 6500 pulling frequency and mode info only and it worked nicely because the mouse didnt effect the logging PC. It does however take more desk space but works
I agree the flex control is a must for this to work well
N9DFD0 -
Writelog.. only because I have been using it forever
I run N3JFP OR N1MM. I prefer N3JFP but N1MM is more versitle at some things and has more preprogrammed contests Mike N9DFD0
What I'd like to see is a dedicated virtual hardware front panel for contesting - sort of like that FlexPad posted a couple of weeks ago.
FlexPad thread.....
https://community.flexradio.com/flexradio/topics/flexpad
The FlexPad picture shows jacks for a paddle, phones and mic in the add on hardware.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 876 Genius Products
- 315 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
