long given up on virtual ports
Hi John,
I'm curious to know what you mean by "remote control" of the Flex-1500? I run all my rigs from any of my computers in the lab (shack) here, using custom code that I write. But currently I do not pipe any audio across the Wifi or Ethernet connections, just command and control.
Right now I use the Flex-1500 as a pan display / RX and have it coordinated with my IC-7600 which serves as a secondary RX and the main 100W TX. Either one becomes master / **** automatically, depending on which one is being tuned. I can command either of these from any computer in the lab (shack) here, over WiFi network. I also command Agilent signal generators for my FMT work.
Concurrent with this command / control I also run FLDigi, CWSkimmer, WSJT-X / WSPR.
[Disclosure: I used to write the systems to control pointing / tracking of the world's largest telescopes. So this radio control code is similar and just as easy to do. The interposer code is written in Lisp and occupies around 100 or fewer lines of code -- a couple hours from one afternoon. Along the way, it intercepts the buggy requests from these programs and reframes them before forwarding to produce the intended effects.]
73 de Dave, N7AIG
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
