W2IHY 8 Band EQ and W2IHY EQ Plus
I am currently using a K3 with the W2IHY 8
Band EQ and W2IHY EQ Plus, and I get excellent on air audio reports. I will be purchasing the FLEX 6700, and I was wondering how does the Flex 6500/6700 downward expander and 10-Band EQ compare to using the W2IHY 8 Band EQ and W2IHY EQ Plus?
Reggie
Hey Reggie,
in my apinion the best results you can reach with Flexradio will be when you connect the MIC direct to it and use the internal equalizer.
PS. I done a lot of tests with Flex 5000 and W2IHY, but the best was without it.
Emil-DL8JJ
Sorry I disagree.
Have had the W2IHY stuff and it works far better than any internal possibilities so far.
For personal preference have found better. But still nothing has came along that is easier to use with early success , than the W2IHY gear . Especially when you follow his mike sugestions and settings.
Very few of us can just plug in a mike and have "Great audio" You know the kind that a un solicited report of "Man you sound fantastic"
For "ME" : I no longer use W2IHY gear
I have also tried rack gear but now prefer Digital audio processing with VST's . Very low noise mike preamps, Studio grade mikes.Staged Compression , Multi track EQing.
At least I have given up Asking "How does my audio sound"
I am curious to what VST's you are using? I am very interested is Digital audio processing.
ok it depends on what I wish to acomplish . For easy to listen audio
By track have tried as many as 8 tracks to 15 tracks
Blue cat dynamics modler
Pro EQ
Blue cat MB5
Fabfilter Satern
Ozone max
There is a major change in DX style where I use max. Compression serious form cutoff filtering in stages to keep the duty cycle up there . Have a hefty amp that really has a workout.
That idea is LOUD Hi
by the way I also used the W2IHY stuff with a K3 Before the flex
I have found the W2IHY gear gives me the best audiowhen used with a Heil PR-40 mic. I have setup sheets i've written for both the 6300 front mic input and 6500 rear balanced line in. I can send a copy to anyone wishing to try my settings. 73 Dave, wo2x3
I have had the occasion to hear and work you And Dave. You do sound fantastic. I would definitely copy those settings1
HI Dave,
I just got my 6300 and have just wired up the PR-781 to work with my W2IHY and would like to have those settings if you don't mind.
Peter
Here is the setup I wrote for the W2IHY gear and the 6300. Pay attention to the level settings, especially the 8 band EQ mic in & out. Once you get it set up, do fine adjustments with someone on the air that knows your voice.
Dave, wo2x
SETUP INFO FOR W2IHY 8 BAND EQ, EQ PLUS, and Flex 6300
By Dave De ****, WO2X
This setup is for the Flex 6300 with W2IHY 8 band EQ and EQ Plus using the 8 pin mic in cable.
Setting radio TX Bandwidth
For rag chewing set radio TX filter bandwidth from 50 to 3500 Hz. If the bands are crowded then set bandwidth from 100 to 3000 Hz. (Voice tab)
Set the SmartSDR TX EQ to OFF
Set SmartSDR +20 dB mic boost to OFF (SmartSDR/Voice tab)
Set SmartSDR PROC to ON and set to Normal position
Set SmartSDR input to MIC
Set MIC level to approximately 19%
W2IHY 8 Band EQ
50 Hz +8
100 Hz +4
200 Hz 0
400 Hz 0
800 Hz +4
1600 Hz 0
2400 Hz +4
3200 Hz +8
Noise Gate off
Mic impedance 600 Ohms (on bottom)
Turn switch on right to ON position to enable EQ.
NOTE – The MIC IN and MIC OUT adjustments on bottom of 8 band EQ should be preset. Only adjust them if necessary.
To adjust MIC IN and MIC OUT
Use a good pair of headphones and plug into the monitor on 8 band EQ. Turn monitor volume up Turn MIC IN fully counterclockwise. Adjust MIC IN (on bottom) to the point where the audio level comes back up but don't go too far, otherwise your mic will pick up excessive background noise.
The RED LED above the on/off switch should NOT blink. If it does, turn the MIC IN counterclockwise to reduce mic input level.
I'll cover the setting of the MIC OUT under the EQ PLUS setup.
EQ PLUS
Set the following:
Equalizer switch off
Bass - approx 2:30 o'clock (See picture below)
Treble - approx 3:00 o'clock (See picture below)
Mic impedance 600
Mic power off
Gain 11:00 (see picture below)
Comp approx 8:45 (see picture below)
Delay 10:00
Level 12:00
Effects 2
DE Level - Fully CCW
Expander Switch - leave off for initial settings, then turn on when you adjust DE Level
Output level. Fully clockwise. (see picture below)
Talk into the mic and watch the limiter meter on the EQ Plus. You should be lighting up three to four green segments on the limiter meter. If necessary, adjust 8 band EQ MIC OUT (located on bottom of 8 band EQ). Make sure the INPUT GAIN knob on EQ Plus is at 11:00.
Turn on the EQ and DOWNWARD EXPANDER switches on EQ PLUS. Key radio and talk into the mic. Adjust Balanced Audio level in SmartSDR so you just get 0 dB on level meter in SmartSDR on voice peaks. (The peak indicator will go from yellow to red when you get to zero)
Turn downward expander switch on EQ Plus on. Plug headphones into the Flex 6300. Turn on the monitor in SmartSDR. Key radio and adjust monitor level in SmartSDR to comfortable level. If you hear background noise turn DE LEVEL on EQ Plus clockwise until background audio starts to mute. Do not adjust too far or the audio will get choppy. On my EQ Plus I leave the DE level fully CCW.
NOTE – My EQ Plus is a newer version where the DE Level knob was changed from a 500K Ohm **** to a 100K Ohm ****. This change has a little bit of downward expansion enabled when fully CCW and makes the adjustment much smoother.
That's it! This should get you close. Now you can tweak to get the settings that are right for your voice. The Heil PR-40 matches up VERY well with the W2IHY equipment.
NOTE – The PR-40 and other dynamic mics can suffer from proximity effect. I find staying about 5 to 6 inches from the mic is the sweet spot.
Get great audio reports with SmartSDR set up DX+ and 10 band software equilizer. Sold my W2IHY box as no longer needed.1
Can't see a picture below as stated0
What is connected first the 8 band equaliser or eqplus ?0
What position does the dexp in ssdr have to be set at on or off0
It goes in this order.
MIC -> 8 band EQ -> EQ Plus -> Radio
If you follow my procedure above the DE/COMP switch is initially off for level settings then turned on later in the procedure.
If you like I will email you a copy of the pdf.
Dave, wo2x
Sorry, didn't read your question correctly. DXP in SSDR should be off. PROC in SSDR should be on and normal position.
Dave
AH !!! Well I also have sold mine , Along with some pretty interesting rack gear , Now running electronic .
What I have found is Audio is very subjective. And Carl , I am glad you like Yours .
There are so many avenues to play audio
. I have found out that internals in the Flex for audio did limit the result .
The 2 box approach W2IHY Again for me fell short on aspects of audio control. (The best results were with WO2X settings)
Rack gear for me was frustrating add another piece and you will get this and that . For Some very good results .
As I became more Aware of what and how to accomplish what I wanted the Electronic Venue offered to me all .
Now it's in search of HD audio DUTY cycle . More FUN !!0 -
Setup as per your instructions and am getting fantastic reports,thanks so much.tony0
Dave really has the ihy. gear figured out.0
Hi Tony,
Thanks for the feedback. The settings seem to work well for ragchewing. I just tighten up to 150-2900 for DX and bring the processor up to DX or DX+ as needed.
Dave, wo2x
Will try that and let you know if it makes any difference to already great audio.tony m6dyr0
Hi Dave just a couple of questions,first the only way I can get background noise off my microphone is if I turn up the de level to max on my eqplus second is what is the purpose of the volume control on the power on/off rotary control on the 8 band equaliser.thanks0
Hi Tony,
In the document above I cover adjusting the MIC IN and MIC OUT on the 8 band EQ. You plug headphones into the jack on the rear of the 8 band EQ and use the knob to adjust the monitor level. Here's the procedure:
To adjust MIC IN and MIC OUTUse a good pair of headphones and plug into the monitor on 8 band EQ. Turn monitor volume up Turn MIC IN fully counterclockwise. Adjust MIC IN (on bottom) to the point where the audio level comes back up but don't go too far, otherwise your mic will pick up excessive background noise.
Another way is the listen to the background noise when plugged in the monitor of the 8 band EQ and adjust the MIC IN to where the noise almost completely disappears. You do not want to turn it too far down or the input circuit will be starving for audio and it will sound like raspy or RFI on your audio over the air. The trick is to reduce the background to where you can barely hear it in the monitor circuit.
That does not answere my second question,what is the function of the volume control on the on/ off rotary control0
Thought it did. When you plug the headphones into 8 band eq to adjust MIC IN it adjusts headphone monitor level0
Found the problem with first question there was a second ground to the shell of 8pin connector cut that off and now I can get de level down to fully ccw no problem0
I thought you adjusted that with the monitor level control on bottom right of eqplus,sorry im thick lol.0
No problem Tony. You using a Heil cable from mic to 8 band? Heil continues to make the cable with a short piece of wire from the mic low pin out around the clamp of the connector shell. This creates a ground loop and introduces RFI. Modern radios work better with that jumper wire removed. Dave, wo2x0
- 338 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 366 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
