PR781 Heil Mic Issue
Joseph Rodick
I have a flex 6300. I am using a PR781 Heil Mic, with the Bal Cable. I am getting reports of motor boating audio, almost like computer generated tone. When I use the Flex Mic supplied with the 6300 the motor boating is gone. Any Clues?
Sounds like RF is coming through the balanced cable, I would put a toroid on it.1
just added four toroid coils on the balanced cable, till getting the motor boating sound using the PR7810
Still sounds like you are getting rf in the balanced line (not sure how but if it doesn't happen when coming through the front panel but does through the balanced line, thats all I know it can be!)
730 -
Just ordered another cable from flex. Thank you for your assistance.
Joseph
WB4SSG
6.1.2 Supported Microphone Types
The FLEX-6000 front microphone connector can support either a dynamic or an electret
microphone. This is an unbalanced high impedance input. The electret bias voltage is not
enabled by default, and must be enabled by SmartSDR. The DB 15 in the back does not provide a balanced input It provides a Plus audio input and a Frame ground .0 -
I had this issue the other day with my 6300. Was using a heil headset with the adapter for the 8 pin mic connection in front of the radio. Several stations said I had the "motor boating" on my signal. I turned on the monitor and sure enough, I could hear it. I unplugged the headset and plugged it back in and it's not done it since.
While adding a toroid to your mic cable may be the answer, people need to understand that all toroids are not created equal. Mix 31 toroids work best for HF frequencies. Mix 43 will work above 10mhz. Unless you are sure of the composition of the toroids you are using, they may not help at all. Almost never are toroids bought at hamfests identified.
Jon...kf2e
2
- 339 Community Topics
- 580 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 367 SmartSDR API
- 9K Radios and Accessories
- 893 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
