New video card installed. Suggestions for optimization?
Ken - NM9P
Member ✭✭✭
I just installed a Diamond Radeon HD 6570 Video card that my brother had as surplus in his gaming computer. (I can buy it from him for $42) I had to go to the AMD support site and download the Catalyst driver software. It has 2 Gb memory and 3 ports HDMI, DVI & RGB. I am hoping to run it with all three monitors. So far I only have it connected to a 22 inch 1080p and a 23 inch 1080p TV/Monitors using HDMO & RGB ports. I have a DVI-HDMI Adapter and cable that I plan to use on the second monitor and then add a smaller RGB when I get it unpacked.
Any suggestions on settings to use with my Lenovo K410 i3 running Win8.1/64 for optimal performance? So far it seems to have a bit less "over-run" on the edges of the pan when tuning with the FlexControl Knob. But it still has some.
I am not sure I am going to keep this video card, but am giving it a test to see if I really want to spend more for a faster one. My current power supply will not supply the 6 pin molex to the HD 7770 that I was looking at on Amazon.
k3nc is 'da man' for stuff like this, IMHO...
i will also be curious w his reply since i recently upgraded to a Radeon 7790 series card...
it recently dropped below by '$100 pain threshold' ..ha!
wondering what amout of 'bloatware' we have to tolerate, mostly...
73, w5xz, dan
Turn off dynamic DPI scaling.0
Thanks, guys. Tim, I will turn DPI scaling off. I don't know what it is supposed to add anyway! The jury is still out on this card. I had to go to the AMD website and download the new Catalyst driver software to get it to run. It seems better than the internal video with fewer over-runs on screen edges. But I don't know if it is enough better for $42 to warrant keeping it instead of going with a faster card for a few more $$$.0
Auto DPI scaling will try to adjust the DPI settings based on your monitor size. If you use a large monitor, the desktop icons can look really large and fuzzy. Manually setting the DPI to 100% (96 pixels / inch) can make SmartSDR look better on large displays when running Win 8.0
Thanks, Tim. I am running 22 and 23 inch TV/1080p monitors, one with HDMI and the other with DVI cable. For TV's they look pretty nice in monitor mode. I am using a dual monitor pole, and hope to add a third monitor, a 19 inch RGB flat panel for my digi mode display which will require rearranging my operating desk, AGAIN.
It is interesting how quickly you run out of "real estate " on the monitors when running SSDR, logging program, digi program, voice keyer, k9DUR memory program, DX spotting, W1AW/p tally sheet, and internet all at the same time!0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
