Erratic flex control with two slices open
Member ✭✭✭
edited January 2020 in SmartSDR for Windows
I was on 17 this evening and I had two slices open on the same band.  I noticed that the Flex control had become very erratic as I rotated the knob.  As soon as I closed one of the slices the problem went away.
6700
v 1.2.17
Welcome!
  • Member ✭✭
    edited July 2014
    Hello,
    the same Problem here, when i open more than 5 panadapters with slices. (Was the same problem with the old one version)
    Emil, de DL8JJ
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Please describe the issue in more detail.  Does the tune rate have any correlation to the erratic tuning of a slice?
  • Member ✭✭
    edited July 2014
    Hi Tim
    You have 8 panadaptes with slices run simultaneusly running.
    Dsilplay Settings are: FPS 30 and AVG 20. Tunning step is 50 or 100 for example. Watherfall are hidden.
    You turn the mouse wheel or flex control quickly. You will notice slowly and time delayed slice tunning.
    PC is 12 core with GTX 770. That schould be enough for the SSDR "thin" Client.
    You will notice this issue when you open more than  5 panadpters with slices to.
    Emil, de DL8JJ
    edited March 2017
    Emil, are you turning the know quickly or spinning the knob?
  • Member ✭✭✭
    edited January 2020
    I tested this yesterday and again today and now it appears whatever was going on with the FlexControl is no long going on :-)  Everything appears to be working ok.
  • Member ✭✭
    edited July 2014
    hey Tim,
    sorry for delay answer.
    When you have more than 5 panadapters each with slice open and you turn the Flex knob quckly, you'll notice  adelaed slice tunning.
    In addition, you will notice udio desroyng on RX/TX to.
    If you have less than 5 slices all work OK, Independent how quickly you turn the knob and you have no audio distortions.
    Summary: The more panadapers & slices  open, the worser the performances.
    CPU still ca. 17-20 % with waterfall minimized.
    Emil- de DL8JJ
  • Inactive Employee
    edited March 2018
    Don,
    One thing I noticed is that the tuning is smoother if you turn off the "Tune Step"   in the RX tab of Setup.
    Dudley
  • Member ✭✭
    edited July 2014
    Dudley,
    with Flex 6700 and more than 5 panadapters with slices open this make no improvement.
    Emil-DL8JJ
    edited March 2017
    I have added this report as a defect for engineering in investigate.  Thanks for the reports and feedback.
