Erratic flex control with two slices open
6700
v 1.2.17
Hello,
the same Problem here, when i open more than 5 panadapters with slices. (Was the same problem with the old one version)
Emil, de DL8JJ
Please describe the issue in more detail. Does the tune rate have any correlation to the erratic tuning of a slice?0
Hi Tim
You have 8 panadaptes with slices run simultaneusly running.
Dsilplay Settings are: FPS 30 and AVG 20. Tunning step is 50 or 100 for example. Watherfall are hidden.
You turn the mouse wheel or flex control quickly. You will notice slowly and time delayed slice tunning.
PC is 12 core with GTX 770. That schould be enough for the SSDR "thin" Client.
You will notice this issue when you open more than 5 panadpters with slices to.
Emil, de DL8JJ
Emil, are you turning the know quickly or spinning the knob?0
I tested this yesterday and again today and now it appears whatever was going on with the FlexControl is no long going on :-) Everything appears to be working ok.0
hey Tim,
sorry for delay answer.
When you have more than 5 panadapters each with slice open and you turn the Flex knob quckly, you'll notice adelaed slice tunning.
In addition, you will notice udio desroyng on RX/TX to.
If you have less than 5 slices all work OK, Independent how quickly you turn the knob and you have no audio distortions.
Summary: The more panadapers & slices open, the worser the performances.
CPU still ca. 17-20 % with waterfall minimized.
Emil- de DL8JJ
Don,
One thing I noticed is that the tuning is smoother if you turn off the "Tune Step" in the RX tab of Setup.
Dudley0 -
Dudley,
with Flex 6700 and more than 5 panadapters with slices open this make no improvement.
Emil-DL8JJ
I have added this report as a defect for engineering in investigate. Thanks for the reports and feedback.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
