Overlapping panes on front console in Psdr v2.7.2
Allen Burrell
On my i7 desktop running windows 7 the newly installed PowerSDR v2.7.2 for my newly purchased Flex-3000 gives overlapping panes on the PSDR console. Band selection and mode panels, for example, overlap parts of the front console and are cut off on the right edge of the screen. Buttons that are displayed are functional, however. Resizing the window does not change the problem. Changing pixel size of the monitor does not change the results, either.
I had this happen when I used power sdr. I believe it is in the resolution.0
I had the exact same problem on my laptop. Here's how I fixed it: go to Control Panel. Click on Appearance and Personalization. Under Display, choose "Make text and other items larger or smaller". Make sure it is set at 100%. My laptop was set at 125%. Once I set it to 100%, problem fixed. Hope this works for you.
Kelley K5KTX2 -
Beautiful. That was exactly the resolution needed. Many thanks, Kelley.
Al, KI7RM
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
