Radio profiles
Since the radio's persistence is now basically a snapshot of the radio I thought how excellent it would be to have radio profiles that can be recalled. For example, let's say I want to set 4 pan adapters without slices centered where I want them and Dax iq channels selected and Dax cp set accordingly then another pan adapter open with one slice on one of the bands covered by one of the other panadapters, I can set this up then save it to a profile name I create. Or..... I set up two panadapters each with a slice set as desired and save that as another profile. Remember, these are snap shots so recalling a profile would set all the panadapters, slices, modes, Dax settings, just as you had left it. If you want to you can click a button to update the profile when closing ssdr. I can set as many profiles as will fit on the computer. This way depending on what operating I want to do all I have to do is select that profile before clicking connect. The profiles should be able to be stored outside of SSDR and a menu of available profiles be listed on one of the settings tabs. If one is not selected then the last profile would be used. Having them outside ssdr would let you save all your profiles on a storage device on your LAN or maybe on cloud storage. Waddy a think? 73 Greg AB7R
I like it. With more RX'es, there's more to set up for a session, and your automation idea sounds pretty cool.0
i would like to see the ability to store settings by frequency and or mode like we were able to do with PowerSDR; it was nice being able to click on the memory for the frequency i use for our section level SSB net then when that was over i could click on the memory location for 20-meter JT65 and all settings would come up correctly set. however, the 6500 is such a great radio i can live without this capability. it took several years to get PowerSDR from where it was in 2009 when i bought the 5K to where it was when i sold the 5K to buy the 6500. Great job Flex, 73
Greg,
What a great idea.
I am battling a battle here. I run multiple programs and at this advanced age, I forget where and how I set it up. Your suggestion would solve my problem.
Thank you
Profiles are on the ROADMAP0
i was just putting my .02 worth in; it's not going to deter for one second the fun i'm having with the 6500. have a great day 73
You can do this to a degree with K6TU's iPad utility. But I would love to be able to save and restore from my desktop, and even saving them to a file offsite is even better.0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 767 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
