DAX issues
Burch Akin
I just recently received my new Flex-6300. I am having two issues with DAX
1) I can receive on DAX audio stream 1 but I can not transmit (I could initially). If I choose DAX audio stream 2 on both transmit and receive, things work fine. This is when using DM780 for digital modes.
2) Even though I have the 6300, it appears that I have 8 DAX receive and 8 DAX transmit streams even though I can only select 1 or 2. When I try and setup MultiPSK it will only display 16 soundcards and of course I see DAX 3-8 transmit and receive streams but not 1 or 2. Is there a way I can delete 3-8 since I can't use them anyway? I really like MultiPSK but I can't select 1 or two.
Not sure why I can't transmit on DAX stream 1 anymore. If I open the DAX control panel I can see the red line like it's transmitting and my radio goes into transmit mode but no power/modulation out of the radio. As soon as I change DM780 to DAX stream 2 for both transmit and receive everything works fine. This started after I installed SDR-Bridge so maybe I should try uninstalling?
After rebooting several times and powering on and off the radio I finally got DAX stream 1 to work on transmit. Weird.... Still have the problem with too many sound devices showing up in MultiPSK. I deleted my VAC audio cables and now I can see DAX cables 2 but not 1 in Multipsk. I need to add the VAC cables back because I still use my 5000 for VHF/UHF.
You can go into the sound cards under playback and recording devices and disable anything about 2. They will not show up as sound cards you can choose in your software... At least that is how they work here using MMTTY. I had the same problem as you with the software not showing all the sound devices such as 1 and 2. 73s Jim K4JAF1
Jim
Thank you! That fixed my MultiPSK issue. Deleted all but DAX 1 and 2 and now they show up.
Burch
Glad to help, I had the same problem with MMTTY. 73s Jim K4JAF0
- 256 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 791 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 738 Genius Products
- 394 Power Genius XL Amplifier
- 257 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 589 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 817 Third-Party Software
