How I interfaced my 6500 to my Quadra amp
In this earlier thread I was asked by John, NA6L to put together the steps I followed to get my Quadra amp to work with my 6500. I have placed a copy of the PDF I put together in my Dropbox public folder and you should be able to download a copy here. Most of this information is available in Steve Nance's great wiki for DDutil but perhaps consolidating it will help some get things working.
If anyone sees any errors or omissions you can email me directly at jhall at hallsweb.org.
Jon...kf2e
Jon...kf2e
Jon, thanks for the nice write-up. Also, might I suggest uploading it to the files section of the DDUtil Yahoo group reflector where it can be referenced easier and not tie up your Dropbox. I can do this for you if you like if you send me the file.0
Hi Steve,
I'll be happy to upload the file. Thanks for providing us with such a valuable tool as DDutil.
Jon...kf2e
Jon, thanks for an awesome piece of work!!
I have been busy building a new PC (mine was 8 years old), I did add a serial port to the new build but now I'll also need to add a parallel port. Because my soldering skills and equipment come to a screeching halt at the thought of small wires and plugs I'll be looking for a source for an interface cable, possibly nearsighted Quadra owners can commission a few?
Thanks again, John NA6L
John,
Email me at my address listed at the end of the instructions and I'll try to help you get a cable.
Jon...kf2e
Thanks for the upload Jon. 73, Steve K5FR0
Jon I have not used my quadra due to lack of alc with the powersdr. I would run it everyonce in a while but watch the drive very carefully . Now with alc available with the 6000 question is the alc responsive with the flex 6500? I run a Alpha 8410 and several other solid state amps including the Sgc 500 which do not require alc. but would like to bring the quadra back online. Just wondering?0
Dale,
I don't run alc on my 6500 with my Quadra. I use DDutil so that it follows my radio and use autodrive to maintain my proper drive levels. I ran it this way on my 5000 before. I know there are those that swear you must use alc but I've never had a problem.
Jon...kf2e
Yes tell yaesu you do not run alc and they go crazy. I have run without alc on my flex 1000, 3000 and 5000 and oh yes my Orion I. I did have a watt meter that would catch over drive and disable the keying circuit. I do believe the quadra is stronger than the Tokyo high poer are. I did use alc with my 1000mp and the ft 2000 and it worked to a Tee.0
I also use an LP100A on the output of my Quadra to protect it from an antenna mismatch. I primarily use a SteppIR which if I do something **** might not be tuned. If the SWR is mismatched the Quadra doesn't key. Between that and the drive levels being managed by DDutil I feel pretty good.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
