RCA TX1 Enable not persistant
Jim K4JAF
Jim K4JAF Member ✭✭
RCA TX1 Enable is not persistant from boot up to boot up..  Anyone else have this problem?
Radio is 6300 with latest upgrade.
  • Jon_KF2E
    Jon_KF2E Member ✭✭✭
    edited July 2018
    If you are looking at whether or not it is enabled before you connect to the radio it will show disabled. After you connect it will show correctly.
    Jon...kf2e
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    No, it consistently shows not enabled after the 6300 and software are initialized and working properly.  Jim K4JAF
  • Mal
    Mal Member
    edited April 2019
    I am having the same problem with my 6700
  • Mal
    Mal Member
    edited April 2019
    OK fooling around I found that TX2 and TX3presist TX1 doesn't
    I set my amp on TX3 and no more problems
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited April 2019
    RCA TX settings are saved in transmit profiles.
  • David Decoons, wo2x
    edited June 2020
    Aare you using DDUtil?
  • Mal
    Mal Member
    edited December 2016
    True, but every time I turn on the rig, I have to go to the transmit profile and load it.
  • Mal
    Mal Member
    Yes I am using it for my Steppir
  • Larry _ NY8T
    DDutil could also be causing the RCA TX issue. Check the box for manual TX control.image
  • Mal
    Mal Member
    I will try it
  • Mal
    Mal Member
    Also my mike profile always comes up with a star next to it, indicating something has changed, but I don't know what.
  • dlwarnberg
    dlwarnberg Member ✭✭
    edited May 2019
    I found that RCA TX1 is tied to a TX profile (notice on the right side a profile listed) once you set it... i.e. Profile Heil Pro Elite AMP, then save that profile... every time you select that profile it will be set
    The second source is also DDUtil as mentioned
    Good Luck
    David
  • Joe WD5Y
    Joe WD5Y Member ✭✭
    edited January 2017
    I had this issue and it was the ddutil setting causing the problem. Hope you get it fixed. Joe WD5Y
  • ctate243
    ctate243 Member ✭✭
    edited April 2017
    2 things.  Check DDUTIL as stated.  One thing I found in learning all this was to set your TX RCA ports as you want them, and save that off as a custom TX profile.  Now as long as you load that particular TX profile you should be in good shape.  This worked out great for me and solved by TX relay persistence challenges.
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited June 2020
    Sure would be nice to have some sort of setting's overview "dashboard" to graphically present the current state of all settings. I've had the TX1 not enabled as expected issue when SmartSDR does a dump and is restarted. Will use the notes here to troubleshoot. Still working on why every now and then SmartSDR unexpectedly terminates, but won't spend very much time on troubleshooting 1.6.21 with 1.7.x just around the corner. 73 Steve K9ZW
  • Tim - W4TME
    edited March 2017
    Every time this issue comes up in Support, it is DDUtil resetting the TX Relay port.
  • KL4QG
    KL4QG Member ✭✭
    edited May 2020
    Cannot enabled any RCA TX here picture image
  • mikeatthebeach .
    mikeatthebeach . Member ✭✭
    edited July 2019
    You are in wrong menu Go to Tx band settings Mike
