Heil PR781 microphone cable for 6300
Charlie
My 6300 will be arriving in a few days and I have a questions about a Heil microphone cable. I own an Icom 7600 and a Heil 781 microphone. I am using the CC-1XLR-I cable with the 7600. Can this cable be used with the Flex 6300 or would I need to purchase a new cable? If I need a new cable is there an adapter for the Icom cable?
Hi Charlie, Since the Flex 6300 is compatible with a Yaesu pinout on the 8 pin foster plug I believe you will need a new cable that adapts the Heil 781 mic to the 8 pin Yaesu type connector.
Cable # CC-1-XLR-Y (for Yaesu 8 pin compatible mic conns)
Larry: Thanks for the reply. I see that there are two CC-1-XLR-Y cables. One is balanced and the other does not have BAL in the part number. Which cable would I need for my 6300?0
Yes, that is the cable you need. And you can get it from FlexRadio using this URL:
http://cart.flexradio.com/PR781-Mic-Cable-for-8-Pin-Foster-connector_p_838.html
- 113 SmartSDR+
- 920 Genius Products
