Antenna 1/2 interface
Tom--W4FAS
I was copying a strong signal at 10 over. I then switched to antenna 2 to see how my other antenna was doing. It was weaker than I had expected at S3+. When I looked at the antenna 2 connector there was no antenna connected. Why should I have heard anything?
I use a quadra amp which has four antenna ports. I swear that sometimes strong signals sound better on a port with no antenna. I suspect the isolation between the ports is such that you are still seeing the signal. I don't think this is a problem.
Jon
There is not 100% isolation between antenna ports so you will hear strong signals on an unconnected antenna port. Like Jon said, this isn't a problem.1
I noticed this a few weeks ago too when I was messing around with antennas. Thanks for the answer, Jon and Tim.
- 336 Community Topics
- 604 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 182 FLEX-8000 Signature Series
- 913 Maestro
- 883 Genius Products
- 448 Power Genius XL Amplifier
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
